Question about Acer Aspire 5520-5908 Notebook
Updating BIOS V1.04 acer aspire
how have you made the update? I'm not able to use the program. Please can you provide me your approach?
thanks
Alex
How to flash BIOS on Acer Aspire 5735
I would firstly clean the fan and radiator then update windows and run a registry cleaner and defragment your hard drive. You should find it clears your issue. If you want to update the bios, ensure you have your antivirus switched off!
Jan 10, 2014 | Acer Aspire 5735 Notebook
Acer aspire 6530 bios update fail, What to do now?
May be not supported bios version, Internet speed slow, Your devices not match that software. I suggest you go to Acer help store and full technical support provides. If local help contact techsupportmart hear good technician available i hope solved you problem.
Thanks..
Oct 22, 2013 | Acer Aspire 6530-5143 Notebook PC
Aspire 1640 series
please desccribe about your problem to solve it immediately ..Thank you for giving me opportunity to solve your problem .
please give your ratings must...!!
Jun 17, 2011 | Acer Aspire One D255-2670
My acer aspire one 532h-2db blank screen but the power is on. please help me! thanks.
Thank you for contacting Fixya. This is Anil.
I understand that the Netbook starts but there is not display on the screen.
It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
Extract the files from the downloaded zipped BIOS file.
In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
Ensure that the AC adapter is plugged in.
Insert the USB flash drive into a USB port.
Press and Hold down the Fn and the Esc keys together and press the power button.
When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
After the keys have been released the power light will start to blink.
During the BIOS update process the display will be blank.
Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
Jul 30, 2010 | Acer Aspire One PC Notebook
How do i update the bios on a acer aspire 4315 notebook? can anyone help??
Please follow the link mentioned below in order to update the bios.........
http://www.laptops-drivers.com/acer-notebooks/download-bios-updated-acer-aspire-4315.html
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Acer Aspire 4315 Notebook
Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
Hi
thank you for your query
Please can you try the following
1) go to www.devicedoctor.com
2) Download and install the device doctor software
3) Once installed open it up and click scan, it will then scan your PC for the best driver
4) Download the driver (entitled VGA driver) and install
5) Restart and see if this cured the issue
Regards
Shauqat
Jun 02, 2010 | Acer Aspire L100 PC Desktop
Acer Aspire 1800 Won't boot
I recently had Acer Aspire One Laptop with very similar symptoms: No screen, no lights (those that indicates activities) except Power button. I first thought the Hard Disk is dead but it's not.
I contacted Acer helpdesk in Australia and they have sent me a document with BIOS update and instructions. I did what it says and then the laptop is back to normal. Yours may have the same issue - need BIOS update. The Aspire One BIOS update requires a FAT USB drive with the updated BIOS and the BIOS Flash program, plugged it in, press and hold 2 buttons: Fn and Esc, then press Power button for a while.
You should seek Acer Support website. But you may need proof of purchase.
May 09, 2009 | Acer Aspire 1800 Notebook
I need a 48 Bit BIOS update for my Aspire 1712SMI Notebook to run a larger HD. Please provide me with a download URL on the ACER web site where I can download it. If you do not have this BIOS, who has a...
Go here. Once here, select notebook, Aspire 1710, then bios. Follow the instructions carefully....a failed BIOS update can render your computer useless.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | Acer Computers & Internet
BIOS problem with Aspire 5500 laptop
hi there,
you can use this iso image booting directly from this CD-ROM and update your bois...
please download this tool using this link....
http://support.acer-euro.com/drivers/utilities.html#BIOS
Apr 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Acer Aspire 5520-5908 Notebook Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
