Question about Frigidaire ATF6000ES Front Load Washer
Error 20 Keeps coming up with e20
  • 2 more comments
  • Counselor11 Dec 29, 2008
    The washer continue to show error code 20. Also, the water will not drain out of the machine, even if you put it on drain/spin cycle..
  • Anonymous Jan 15, 2009
    It starts washing then have way through the cycle it stops and says Error 20, and shuts down with water still in the bottom.. what do i do to fix this problem.
  • gummer8 Jan 16, 2009
    I have exactly the same problem. BUT I caused it by washing a rubber-backed rug that fell apart and is plugging up the works. Have not been able to find anyone to work on it but did find a solution - use garden hose w/spray to spray top of drum, while manually turning it, to wash debris to bottom so it drains out.
    hope this helps someone
    ps haven't tried above yet but will right now :)
  • Anonymous Mar 10, 2009
    It won't finish cycle. It stops on E20, and the water sits in the bottom. It ALWAYS seems to stop in the wash cycle.
    President:
  • 373 Answers
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Posted on Dec 28, 2008
  • 3 Answers
Take off the front panel, two screws on mine. On the right side you will see the pump with a black drain "boot". We raised the washer onto blocks and put a basin under it to catch the excess water. If you can't drain it, your gonna need a shop vac. There were three approximate 1 1/2" clamps, you'll need a pair of straight and channel lock pliers. (I replaced two of the clamps with radiator clamps to make it easier next time) Once you remove the 3 clamps theres a spring loaded clamp at the top of the boot. Lossen that and remove the boot. There is a plasic seine inside with about 3/8" holes. Clean it out. I found the missing blue sock, a string from a sweatshirt, two wire clamps, a paperclip and $1.26 in change. Check the pump impeller and make sure it is clear ans put it back together. Run a load before rplacing the front panel in case you need to tighten the clamps more. Hope this helps.
Posted on Mar 09, 2009
I fixed mine by uncloging the drain cup in the black hose that hooks up to the water pump
Posted on Jan 30, 2009
Tumble action washer keeps giveing me E20
first, find a manual or contact tech support to determine what an e20 means. it could be a clogged drain.
Jun 02, 2014 | frigidaire.com
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
E20 keeps coming up on my washing machine
E20 Error Code - means, not draining
It seems more as an issue of a clogged drain line, filter go to bad or malfunction pump.
Hope this helps.
Mar 31, 2011 | Washing Machines
E20 error code
E20  error is a problem with the focus on the CD reader.
If the error only occurs on one CD then it's most likely a problem with a smudge or scratch on that CD and not the CD player  lens .
Try cleaning the CD thoroughly with iso-propyl alcohol
Nov 06, 2009 | Car Audio & Video
My washing machine keeps giving me a error 20 code and dosent finish the cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes2.gif 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash2.gif. let me know what code come up... hope it helps
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a 97 Buick Regal and I get a E20 error message:cd player
It's just an error message. It stands for Error 20. There is no way to fix the problem. It only reads cd's that it wants. But if it does play a cd, then suddenly stops, and says E20 and spits the cd out, it's most likely because the cd player got too hot. My car does that all the time. And it won't play a lot of burned cd's. Hope this helped.
Mar 24, 2009 | 1997 Buick.5 Regal
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
