NEC NHD-2000 HD Receiver - no power
Hi
My NEC NHD-2000 HD Receiver stopped working today. Simply has no power. No time, no standby and will not turn on. Have tested the power source and it looks fine.
Any ideas?
TEN TO A PENNY THE REGULATING IC WITHIN THE PRIMARY SUPPLY HAS BLOWN AND IF THAT IS SO THERE IS NO REPLACEMENT FOR IT. I AM TRYING TO FIND THE CIRCUIT FOR IT SO I CAN FIND ALTERNATIVE SO I CAN FIX MY OWN.
BUT OTHERWISE BUY A NEW ONE THE CHEAPEST YOU CAN FIND JUST AS GOOD AS THE EXPENSIVE ONES
Posted on May 27, 2011
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Feb 14, 2016 | Marantz SR7005 Receiver
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
My receiver simply will not turn on. Power source is active.
Try changing the power press button. If the standby led works.
Sep 18, 2010 | Yamaha HTR-5280 Receiver
Remote and manually not working ,batteries ok,power on ok ,no obstacles blocking remote,turned off power worked for short time, stopped again.nec high definition receiver,model nhd-2000
one of the batteries was not making proper contact and was loose,had to gently stretch spring contact out to make it stay in place .kept dislodging itself,so far so good.thanks
Dec 06, 2009 | One For All URC-5705 Remote Control
Hi, I have an NEC hi-def-receiver, model NHD-1000, just recently it has been turning itself off, power is still there, has 4 lines instead of time but it loses the signal. 4 symbols appear when it shuts...
I had the same problem and found it was caused by dry solder joints in the output pins of the power supply board. Solved it by resoldering the joints.
Nov 24, 2009 | Kitchen Appliances - Others
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
HK AVR25 MKII goes on and off numerous times on cold power up
The relay on the PWR SUPPLY board clicks once when the PWR switch is turned on then 2 to 5 sec. later it clicks again and 'off' it goes.
The small transformer ( standby power) on the board appears to be leaking crud (looks like wood glue) all along one edge.
Can I bypass this relay to see if the power transformer is 'ok'?
Jan 16, 2009 | Harman Kardon AVR 25 MKII
Brand new avr588 receiver is turned on....is on for five seconds and then cuts off to standby
Hi donnie025,
I can't believe you haven't received an answer before now.
The red flashing light normally indicates that the protection circuit has been tripped. It can be caused by something as simple as a short in a speaker wire. Even if there is one strand of loose wire that makes contact with the back of the receiver, another wire, etc. it can cause a short. To protect itself the receiver will simply shut down.
1st. I would suggest disconnecting all the speaker wires from the back of the receiver. Then turn on the receiver (obviously you won't hear any sound) and see if the receiver does the same thing. If it does you should try disconnecting all of the source components (DVD player, Cable box etc.) and try again. If it still does it the receiver is bad and needs to be serviced or exchanged if you still can.
2nd. If the receiver stays on after you disconnect, then turn off the receiver and connect one speaker at a time, then power on the receiver at test it after connecting each speaker. This way if it suddenly shuts down after connecting a speaker you know which speaker or wire to check.
Let me know how it works out for you, I hope this helps if you haven't figured it out already.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 08, 2008 | Denon AVR588 Receiver
'standby' mode
I cannot decipher the '66' but essentially all modern sets don't turn off completely, but go to a low-power state.
Otherwise, no remote would ever work; the IR receiver has to stayed powered up if the set must respond to the remote IR transmitter.
Aug 14, 2008 | Sony KP-53HS10 TV
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
