Question about Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter
ADAM 4520 Adaptor does not support 76800 baud rate
I am working at a BMS field and I use ADAM-4520 RS232/485 Converter to communicate a controller to my PC.
It is found that this controller should be commissioned at 76800 baud rate whereas our converter doesnot support that baudrate.
What can be done to increase the baud rate to 76800?Is there a driver that can clear the issue. ??
Your reply will be greatly appreciated.
Regards,
XYZ,
BMS Engineer
4 Suggested Answers
  • 537 Answers
SOURCE: Advantech ADAM-4520 Serial Adapter
The ADAM-4520 is a converter between RS-232 and RS-485/RS-422
Look on this link for the FAQ for the ADAM-4520
http://www.advantech.com.tw/support/sr_detail.asp?SR_ID=1%2D1ZFWI0&SEARCH_TYPE=FAQ
But to answer your question about converting from 9,600 baud to  19,200 baud, I'm not sure I understand. The device should support those data rates. It all depends on what you need to do.
Posted on Oct 30, 2007
SOURCE: 485 to 232 conversion
<Dear Sir can ADAM-4520 transparently converts 485 to 232 as it does for 232 to 485>
Yebo, yes it can. Thanks for calling me sir.
Posted on Dec 04, 2008
I think ADAM 4522 can as it is configurable
Nilesh Desai
NDS Compnents
Posted on Nov 19, 2012
How to change baud rate please
Not sure why you want to change baud rate. This should be automatically negotiated with the system you are communicating with....
What is the problem you are attempting to solve?
May 26, 2016 | Canon FAX-JX200
Need to lower baud rate on my Brother 4100
The baud rate or communication speed of the Brother 4100 Fax is not selectible by the user. It is factory set to begin at 14.4 (the highest speed) and fall back in increments until reliable communication is established.
Oct 20, 2009 | Brother IntelliFAX 4100 Laser Fax
I cant figure out how to lower the baud rate on a brother intellifax 3800
On Brother machines the baud rate is set automatically during the handshake with the other machines, turning off the ECM usually helps when you are getting a lot of communication errors.
Sep 01, 2009 | Brother IntelliFAX 3800 Plain Paper Laser...
My system tell me that my serial port is running at 9600 bad. My motherboard is new enough to be running at top speed. What is the problem and is there anything I can do to fix this?
The mother board can be new enough to run at 19200 Baud rate or even more but most of the devices run at a baud rate of 9600. If the baud rate of the motherboard is increased then the communication between the device and the motherboard can become an issue.
If you still want to change the baud rate then the option will be available with the software you get with the device you are using with the serial port.
If I can know the device attached to the serial port then I can help you further.
Kindly Comment.
Jul 23, 2009 | Office Equipment & Supplies
4800 baud rate communication in vb
You have to change it on both side!
If you are communicating your PC with a serial device, BOTH must have the same speed (serial device: 4800, pc: 4800)
Have you done it?
Most devices DEFAULT settings are 9600 baud rate, N, stopbit1.
But you can change it depending on the device...
Jan 03, 2009 | Computers & Internet
Problem with an usb-rs232 adapter
There is a good chance the weak spot is your serial to usb adapter. The signals are not compatible so the adapter has a chip and serial driver to convert the signals. If the adapter is not fast enough to convert the signals, you get an error. Here is some more info on adapters.
5 Steps for Selecting the Right USB to Serial adapter
Mar 04, 2017 | Televison & Video
Jun 27, 2008 | Advantech ADAM-4520 (ADAM-4520-D2) Serial...
Oct 30, 2007 | Advantech ADAM-4520 (ADAM-4520-D2) Serial...
GPS Com Port Settings
Maybe you can try on com port 7 with baud rate 57600.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter Logo
117 people viewed this question
Top Advantech Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Stan Ford
Mishan Kasiparsad
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
