Question about Nintendo Wii Console
Wii Remote will not stay sync with console
Wii Remote will not stay sync. I have resync the remote and it worked fine right through Wii set up. But it will drop out as soon as I selected 'start' in a game or start in mii.
  • 1 more comment
  • catong1 Dec 28, 2008
    Only 1 remote used. I just bought my wii today......I have used the batteries that came with the box.....
    I have also tried the re-sync steps above and have always managed to sync my remote and go through all the Wii set up. But it will only stay sync until I pressed start for a game or start in mii. Then it drops out.
    I also found I have to re-sync my remote everytime I turn off my console and restart......
  • Finallyjojo Jan 24, 2009
    My problem is exactly the same. Each time after entering a game/channel, the wiimote disconnected. I tried 2 wiimotes, same results.
    Before this problem occured. I have play Wii for several months.
  • Brodie
    Brodie Jun 11, 2018
    What is Nintendo number
    Problem Solver:
  • 5 Answers
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Posted on Dec 28, 2008
    Problem Solver:
  • 19 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that, explains step by step to fix the problem without any Technical knowledge. I hope this guide will solve your problem. It also gives information. on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 21, 2009
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
Cant resync wii controllers following directions
right to resync the remotes you need to open the little door at the front of the wii console then there should be a red button behind it then open the wii remote where the batteries are then theres a little sync button and hold in both buttons then the remote and console should link up
Jan 25, 2010 | Nintendo Wii Console
Wii remote not working, no lights nothing, new
have you tryed to resync the remote if not i ll tell you how to do that
first of all you need to open the little door on the wii console cause theres a red button behind it
then open the back of the wii remotes and there should be a little red button with sync written underneath
then hold both red buttons for a few seconds untill they both sync up cause the light on the bottom will contiunely stay litten
Jan 24, 2010 | Nintendo Wii Console
My wii remote won't connect to my friends wii but connects to mine just fine
You will need to resync the remote back to your wii. Take off the battery cover and open up the flap on the front where you put a memory card in. Push the red button by where the batteries go on the wii remote and the red button above where the memroy card slot is, both the wii and wii remote should flash and eventually the first light on the bottom of the wii remote should flash indicating a successful sync.
Dec 29, 2009 | Nintendo Wii Console
Remote not talking to console
If your remote is giving out and not allowing you to continue , then yes it could be bad..
But, its hard to tell since you just got the system and the new remote is already bad?
If its not staying in sync, then I would try a different remote before thinking any repair options
My handsets wont sincronise with the system, I have fitted new batteries
Follow this procedure:
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
* If multiple Wii Remotes do not work, or you only have one Wii Remote, a repair of the Wii console is necessary.
Oct 20, 2009 | Nintendo Wii Console
Remote wont work when trying to connect to wii menu
There's two things I know of that could be causing this: either the batteries are too low, or the remote is no longer synced to your console for some reason. The batteries are easy enough to check--just replace them and see if the problem is fixed. If that doesn't work, try resyncing your remote. Each remote has to be synced to your particular console, and won't work on any others. There are buttons you have to press on both the remote and the console that sync the two together--there should be detailed instructions in the Wii manual.
May 09, 2009 | Nintendo Big Brain Academy: Wii Degree for...
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
Feb 09, 2009 | Nintendo Wii Console
Wii remote wont work after installing wii fit
From Nintendo:
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Jan 02, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
705 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
