Rundll32 stopped working
Running Vista Home (dutch) edition.
When I click on a Mpeg Icon (on an external HD) I get the above message.
  • 13,433 Answers
You may have some corrupt files in your computer, I would suggest you do a disk check
Hold down the windows key and press R type in cmd and press enter
in the cmd window type in chkdsk /F /X C: you will probably have to restart the computer to perform the operationg if you don't want to restart you can simply type in chkdsk C: or you can also do the check from going into my computer right click on the c drive select properties then tools and disk check.
Posted on Dec 28, 2008
My iqon hard drive will power up but i cant access it
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Source
Nov 26, 2012 | Computers & Internet
Tip
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
on Oct 08, 2010 | Computers & Internet
Ram Problem
RESOLUTION To clear the RILOE NVRAM and eliminate the error message, reset the RILOE using one of the following methods:
On servers running Microsoft Windows :
  • Reset RILOE through the Management Agents icon in the Control Panel:
    1. Click Start, Settings, Control Panel, Administrative Tools.
    2. Click on Services.
    3. Stop the HP Insight Server Agents.
    4. Click on Start, Settings, Control Panel.
    5. Click on the HP Management Agents icon.
    6. Click on the Remote Insight tab.
    7. Click on "Reset Remote Insight Board" (reset option will be grayed out if the Server Agents are still running).
Or
  • Reset RILOE using the Remote Insight Setup Utility in the Control Panel (pink icon).
On servers running other operating systems and as an alternative method for servers running Microsoft Windows :
  • Reset RILOE by powering off the server and unplugging the external power connection to the RILOE board and the external power connection to the server.
A permanent resolution is not planned as the Remote Insight Lights-Out Edition (RILOE) is end-of-life and out of production.
Jan 22, 2010 | HP Compaq ProLiant DL380 G2 Server
In windows vista ultimate 64 bit. most of the items in my control panel will not open up. I get this message. c:\windowssystem32 undll32.exe file name or extension is to long. can you please help me. jim
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } hi
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
The rundll32.exe file operates by parsing the command line. The specified DLL is then loaded through the function LoadLibrary(). Afterwards, from the function , it gets the addresses through GetProcAddress(). The command line tail is passed when the is called. Next, the DLL is unloaded upon the return of . Finally, the rundll32.exe file exits.We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
if you have any question or any futher assistance you can get back to me on fixya for same
thanks
techbuddies
Oct 25, 2009 | Microsoft Windows Vista Ultimate Edition
Weird clicking sounds
FOR MACINTOSH OSX:
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Windows Explorer sends continuously error messages
Turning off thumbnails will probably stop you getting that error
DO:
Open Control Panel > Folder Options > Always show Icons, Never Thumbnails
However, this isn't actually fixing the problem.
Do you have Nero installed by any chance?
If so try:
Open Computer > System Drive > Program files > Common Files > Ahead > DSfilter.
Rename "NeroVideoProc.ax" to "1NeroVideoProc.ax"
Also rename "NeVideo.ax" to "1NeVideo.ax"
And then reboot.
Nov 11, 2008 | Computers & Internet
Vista theme problem
may be while installing, this particular file hasn't been installed properly, so the only way is to re-install the OS....
Oct 27, 2008 | Microsoft Windows Vista Ultimate Edition
I cant scan!
Resolution : I
1 Scan using Windows Fax and Scan
Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  • Click New scan .
  • Click File , and then click Scan .
  • Option two: Scan using Paint
    1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
    2. Click Paint .
    3. Click File , and then click From Scanner or Camera .
    4. Click Scan .
    II nd issue :
    Problem :
    'An error occurred while communicating with scanning device' Message Displays in Windows Vista When Scanning
    Then refer to
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01290511&cc=us&lc=en&dlc=en&product=441125
    Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
    Windows host process rundll32 has stopped running in Vista System
    OMG! there are tons of reasons NOT to use the geek squad. I get geek squad victims in my shop every week. This can probably be figured out remotely- but if it came from BB- I would just about BET it is norton, or spysweeper as the root of the problem, or perhaps an incompatable program on Vista. There might be a problem with the motherboard too- and checking on Dell's site to see if your unit is in warranty will yield a free tech support from thm if the service tag shows a valid warranty. If replacing Norton and spysweeper with a less problematic program like AVG FREE edition (which works a lot better and is FREE!) does not help- there are other cheaper local or nationwide helpers that can fix this remotely (like me)
    Jun 21, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
