Question about Acer Aspire T135 PC Desktop
Method for opening tower
I have a T135 Acer Aspire computer. I accidently put my camera XD memory card into the incorrect slot. How do I open the tower to get the card out? Regards Bob Brownley
  • r_brownley Dec 28, 2008
    Hi
    I put it into the slot immediately below the XD slot.
    This slot is marked CF.
    Thanks Bob
  • Chris Fell
    Chris Fell May 11, 2010
    Which slot did you put it into ?
    the tower can be accessed by unscrewing the screws on the rear of the side panel, look from the front and remove the side panel to the left, undo the two or three screws, slide the panel back and out to see insid ethe pc. You do need to know wher you put it though !
    compdoctor2005@btinternet.com
    Scholar:
  • 172 Answers
Hi Bob, you put it into the Compact Flash slot. Do you have a wife ? with make-up tweezers ?? these usually work. no need to take the side panel off, you will not be able to access it from inside the unit.
chris
Posted on Dec 28, 2008
I have a acer aspire and the screen is not turning on and I am getting a beeping noise about every minute
Hi. Open your CPU side cover then take out and cleaning slot of motherboard also memory connector cooper, careful to fix it before power on again.
Jun 27, 2011 | Acer Aspire T135 PC Desktop
Can I use DDR2 in an Acer Aspire T135?
The e RAM specifications for your Acer are -
Memory - DDR 266/333/400 expandable up to 2GB
Jun 11, 2011 | Acer Computers & Internet
Cannot upload picture from my olympus camera model 600uz to my computer acer aspire model T135
There are 2 ways to do it. First is with the USB cable that came with the camera. Plug one end in your camera and the other end in your computer. Turn the camera on if it doesent come on when plugged in, and the computer will install the camera driver. Once its done, you shouls see a box asking you what you want to do. It should say something like "Play a slideshow" "Import Pictures" "Open folder" ect. you can either import them or open the containing folder, right click on the folder and click copy. Then paste it in "My Pictures" or on your desktop.
The other way is to take the memory card out of the camera and put it in your computer. On the T135 there is a few media card readers right in front a few inces down from the DVD-ROM. Once you put the card in a box will pop up on the screen. Follow instructions from above.
Apr 18, 2011 | Olympus Cameras
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
Jun 21, 2010 | Acer Aspire T135 PC Desktop
My computer cant detect the memory card when i put it in
Hi dear, make sure your computer recognized the card reader first,Then insert your XD card into your card reader.
Jan 17, 2010 | Fuji FinePix Z5fd Digital Camera
Where is the photo card slot and how does it work
It looks to be on the left hand side inbetween the Network and the PCMCIA slots, you should just be able to insert you camera card into the slot and it detect it, it supports the following type of media:
Memory Stick PRO Multi Media Card SecureDigital xD-Picture Card
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
Instruction manual misplaced. Want to insert Memory Card from digital camera and don't know how? H E L P a very non-techie!! Laptop is Acer Aspire 5315. Ta.
what type of memory card u want to insert the memory card slot is on the left side of the laptop beneath expess card slots next to usb ports on the left side , pls check that it supports the card u are trying to use for reading it, it only supports XD/SD/MS PRO DUO/ and not mini sd or trans flash or mmc or some other types the slot is clearly marked with icons of the card types it supports just press this like one inch slot which contains a dummy card to fill the space just push and this dummy card will come out from the slot then insert the supported card type into the slot and the windows will recognize it in my computers as a removable drive icon , pls let me know if i can help u more on this
and pls rate me fixya if i have fixed ur problem
regards
zohail
Mar 02, 2009 | Acer Aspire 5315 Notebook
Problem with memory (xd) card and camera
Look for a manual lock next to your XD memory card slot on your computer. Your computer may not have one but there are a few that do.
If there isn't one, go to My Computer, look for your memory card in the window. Move the mouse over to the memory card and select properties. Make sure that the read only box isn't filled in. If it is, click on it until it is empty.
Copy the contents of the memory card to your computer. Reinsert the memory card into your camera and reformat the memory card in your camera for the utilities option on your camera. If it doesn't reformat, there could be something wrong with the memory card.
Aug 31, 2008 | Olympus Stylus 700 / 700 Digital Camera
Memory stick stuck in the slot
Turn OFF the laptop and remove the battery. Try using a Paperclip or if you dare, open the laptop and you can get the memory card easier that way.
Apr 07, 2008 | Acer Aspire 5100 Notebook
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Acer Aspire T135 PC Desktop Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
