Question about Daewoo DVRS05 DVD Recorder/VCR
DVD drawer will not open, has locked DVD in
Daewoo DVD/Video recorder combination has DVD RW+ disk locked in it was recorded by another type of DVD recorder. How can we get it out?
I am assuming the electronic disengage button is not responding.
Exit programme and use a paperclip gently into the small hole in face of draw and it will trigger a manual release
Posted on Dec 28, 2008
Having trouble with my PIONEER DVR-RT500 recording DVD+RW
(-) R is the industry standard, (+) R is Sony standard, suggest you stick with (-)
Nov 28, 2017 | Pioneer Televison & Video
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?┬▒RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
My recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Apr 05, 2010 | Daewoo DVRS05 DVD Recorder/VCR
I recorded a video in my sony handycam dvd and its haf recorded.now it is showing a msg that do u want to make it recordable.i want to keep the previously recorded video and continue recording.what do i do...
The possibility of this varies from handycam to handycam but it is most likely related to the type of disk you are using.some disks can only record one session. it is important to read the instructions that came with the disk.generally disks marked 'DVD-R' can only record one session whereas disks marked DVD-RW can record several sessions and can even be erased and recorded on again as new.
pse reply if this helps you
Luwangula
Sep 10, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Every disk I put in to record something says bad disk
There's very little information about your problem, like model and disks you are using. I can give you general information.
All DVD's doesn't work will all types of recorders.
DVD Types:
  1. DVD-R, DVD+R, DVD-RW, DVD+RW, DVD-RAM, DVD-ROM, DVD+ROM.
For More In-Deph detail of DVD Formats, Enter Here.
Check what types of disk your equipment uses. Maybe needs lens cleaner or is a equipment malfunction. If it reads, then most likely is in good shape. From my experience, I have two DVD recordable setup boxes. But one only accepts DVD-RAM and the other accepts DVD+Recordables and ReWritables.
If this can't help, you can post more detail about your equipment.
Jul 06, 2009 | Daewoo DVR-06
Daewoo DVD video combo DF4150p
I have had the same problem, however next to the empty folder ( black box) it says MY DVD and a size. if you have that then it has recorded and just press play
May 26, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Dvd recorder
Hi Nickstart, start checking if the problem is related with the kind of Disk and test on different brands, disk types.
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
Your DVD supports the following DVDs -R, -RW, -RAM, all -R disks are supported both on 3'' and 5''.
On +R it just writes regular DVD +R, DVD +RW and mini DVD +R are not listed in DVD specs, therefore are not supported on writing.
When your unit records DVD +R it changes the format to DVD-V, The usint does not support DVD+RV.
I assume it works better with -R
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
See also the manual here, at page 6 and 7 it also says: "Play may be impossible on some DVD-RW (DVD Video Recording format), +RW, CD-R or CD-RW discs due to the condition of the
recording."
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Sep 08, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Dvd-r or dvd-rw discs not recognised
my computer not reconocing tha sofware of my camera, not open fails.disk of sofware is error help me please
Aug 12, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Nov 13, 2007 | Emerson EWR10D4 DVD Recorder
Daewoo DVRS05 DVD Recorder/VCR Logo
294 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
