Question about Teac Audio Players & Recorders
The volume will not turn down
TEAC A-H300mkIII integrated stereo amplifier. The system is 1 year old perfect condition never knocked and carefully used.
  • 24 Answers
Do the volume controls on the stereo itself (not the remote) work? Try using a universal remote to lower the volume.
Posted on Dec 28, 2008
I have a Teac a-R600 integrated amp. The muting light strarts to flash after about an hour playing and mutes the sound until unit is switched off and re started. Any ideas . Thanks Ian
YOU ARE GOING TOO FAR IN VOLUME CONTROL AND YOUR AMPLIFIER TRY TO PROTECT ITSELF BY MUTING-MAKE YOUR VOLUME LITTLE BIT DOWN.IF THE PROBLEM REPEATED WITH LOWER VOLUME SETTING YOU WILL HAVE INTERNAL PROBLEM.ANYWAY CHECK YOUR CABLES FOR GOOD CONDITION.
Dec 19, 2009 | Audio Players & Recorders
My su g90 shuts off when i turn it up loud what do
Amplifiers get hot. The more you crank the volume up (or use extended for extended periods), the more current is required. When it gets hot, there is a fan motor (on the back), that should turn on. I believe your fan motor (brush) is worn out and therefore non-functional. Under this condition when the system overheats, it automatically changes mode to protect circuits.
Also note: if it works when you initially turn it on (cold) for a few minutes it should work fine...until it starts getting hot inside the case.
Oct 20, 2009 | Technics Audio Players & Recorders
Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Mar 14, 2009 | Teac PD-H300 CD Player
TECHNICS SC-CH550 STEREO SYSTEM
Hi
I belive that you have a lot of dust how is gatherd behind the system in the amplifier and it is preventing it to cool down you need to blow it clean and make sure that you keep the system gets cool air
if the temp in the amplifier gets to high it shut down the system instand of burning it very clever solution from the manufacturer
you have a very good system good luck
Jan 04, 2009 | Technics SC-DV290 System
Amplifier will only put out "faint" music, etc, even when the volume is turned all the way up
This may sound silly, but please check to be sure that the tape monitor switch in not engaged. Update this if that is not the problem.
Dan
Sep 29, 2008 | Audio Players & Recorders
JVC AX-33 Stereo Integrated Amplifier - very little sound!
Hi xaser
Check that someone has not turned on the tape monitor or mute. Both of these may cause the problem. Is there alot of noise with the sound you are getting when you turn it up?
regards
Graeme
Mar 22, 2008 | Audio Players & Recorders
TEAC A-h500 integrated stereo amplifier
you have a defective power output, you have to replace it.
Jan 13, 2008 | Teac A-H500 Amplifier
Integrated Amplifier - Volume Control Problem
Hi there, get down to your local electronics supplier and buy a tin of spray switch cleaner. Try and spray some into th v/control and do the other controls at ther same time, this should solve the problem
Aug 27, 2007 | Audio Players & Recorders
185 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
