Question about U-Line 75WC Wine Cooler
Unit not running (cooling)
My 75BWC is 10 years old. The unit is getting power because the inside light comes on. However, the refrigerator is not running. No sound, no heat, nothing. I've not a great job of keeping it clean behind the bottom grate. Did I kill it? Would it be the motor or condenser? How could I tell?
    President:
  • 1,462 Answers
Feel the motor and see if warm. if so and not cooling then that is where problem is. more likely is the thermostat. (ignore earth wire to stat). this can be 2 or 3 wire usually. short together and see if compressor starts up. if so thermostat is at fault.
Posted on Apr 24, 2007
SOURCE:
MAYTAG SIDE BY SIDE MSD2650KEU
Check to see if the compressor is running and hot. Post back your results.
Dec 05, 2012 | Maytag Refrigerators
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Feb 15, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
I have a uline 75bwc and the repair man said the compressor is bad. It's only 7 years old. Should I replace the compressor or is it cheaper to but an new unit?
The compressor is the heart of the unit. As long as the unit is in good shape it would be cheaper to replace the compressor. This unit is a simple unit so all the parts hold up pretty good.
May 17, 2009 | U-Line 75BWC
U-Line 75BWC
if 10 years old then probably has a phial type thermostat. this may have 2 or 3 wires to it plus earth. connect all the wires together (but not earth) and if it is a stat problem, the compressor will start
Sep 05, 2008 | U-Line 75BWC
Hi ,
My fridge motor will not kick in or make any sort of sound, there is light on in fridge, where would I find the fuse or overload button.
I need help, thankyou. Coaxing.
Jan 18, 2008 | Refrigerators
Two year old Maytag Fridge not cooling
pull the power plug for 15 minutes, then plug back in...same problem? tried adjusting temperature control knob (thermostat)? if yes to both questions, freon has escaped out of loop or faulty thermostat. Attempt force start of compressor with jumper clips: pull the power plug then find the two wires into motor and apply 120 VAC from jumper clips. If it spins, then faulty thermostat.
Jun 18, 2007 | Maytag MTB2656G Top Freezer Refrigerator
U-Line 75WC Wine Cooler Logo
280 people viewed this question
Top U-Line Furniture Experts
Sal De
Lollo Pop
Craig Butler
Craig Butler
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
