Question about AEG Lavamat W1050 Front Load Washer
Replacement of drum bearing
AEG Lavamat W 1030
How is it replaced?
    Guru:
  • 558 Answers
Thanks for using FixYa.
Check this website and get the useful info for how to Replace the Drum Bearing --:
http://www.repairclinic.com/0100_25.asp
RepairClinic.com
Happy Holidays!
Scott
Posted on Dec 29, 2008
    Genius:
  • 1,550 Answers
Unplug the washer and pull off the top panel. Screws at the veryback of the top panel secure it to the washer frame. Remove thesescrews and then pull the top panel slightly back and then up and off ofthe washer
http://media.fotki.com/1_p,wfqtgkbbfbbgqkqxgtqsskgwtqkq,vi/grgfkbwwbxgrrgwrkkg/1/1303472/5961857/image56019img-or.gif
http://media.fotki.com/1_p,wfqtgkbdtbgrsstxgtqsskgwtqkq,vi/gwwdffwgwxgwqtrqrbt/1/1303472/5961857/image56018img-or.gif
  • 10,515 Answers
It really is a two man job and I put my back doing this with him. The bearings were much larger than previously encountered. Very! basically you have get out the residue water, release the door seal and (pipe attached) spit the m/c casing, unclip all hoses attached to drum, unclip all drum wiring ,remove belt (note position) remove motor &, lay to one side, withdraw nylon pins from shock absorbers, Look for and remove the little earthing cable set just inside the pulley rim. Carefully release drum/case supporting springs (mark positions top and bottom) and, drop drum/case onto some blocks and lift/pull/take out (really needs two people) (minding other modules). Split drum/case ring of bolts, remove front half (careful here not to damage the heater). take half containing drum outside, lay drum face down and use a drift to hit the socket headed screw securing pulley hard to shake up the taper. Remove this screw (needs good quality allen key) and use wedges to the force off the drum drive pulley. Support drum casing on blocks or put drum on its side, support the drum if on its side and use a heavy drift and hammer to knock through the drum spindle. Careful now to avoid grating hands on the sharp drum holes. With drum now removed place the casing drive end up (ensuring protuding heater is clear of the ground!) put a large bolt (head down) inside the first bearing and rest it on the edge of the inner bearing. Carefully working round the inner bearing edge use a hammer and the bolt head as a drift to knock out the inner (the larger of the two bearings and inturn the drum seal) (note seal postion). Turn over the casing and knock out the outer bearing from inside the drum casing. Clean all and check condition of spider/spindle & renew if damaged. Fit the new outer bearing then the new inner followed by the seal. Dig out the old and renew the (green) O ring seal between the drum casing halves. Replace all, but give a quick test run before replacing casing to ensure belt is positioned correctly. The job would have cost £115 which I think is well worth paying someone to do....
Thnx.
Belt slipping off
did it sound loud on spin if it did
check your bearing as they may be worn and need replacing
or your pulley may be damaged
Jan 11, 2014 | AEG Lavamat 74640 Front Load Washer
Drum is making some really nasty banging then screaching sounds when entering high spin - any ideas??
sounds like main drum bearings not common but if the bearings are worn you get the banging noise and as it slackens the drive belt you get screeching noise as the belt slips.
Nov 21, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
It is very noisy. The plumber said the barings have gone and I have to buy a new machene, but I only bought it 2004. Can that be? Do you have a better plumber in London NW8? Many thanks. Mrs H. Lee
why is plumber telling u get new machine-- look for an appliance repair shop and have their tech look at machine- if bearings their are a few of them and replacing certain ones are not that expensive and if bearings have damaged the drum the price of fixing/replacing might be just under the price of new or replacement machine -
Mar 05, 2010 | AEG Lavamat 72640 Front Load Washer
Drum bearing neads renewing i nead diagram of assembly can anybody help
What is the exact model #?
check inside door of washing machine sometimes on the back, top area.
Some washers require special tools to replace the bearings.
http://www.pdxappliance.com
Feb 27, 2010 | AEG Lavamat 88840 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG LAVAMAT W1450 SOMETHING LOOSE IN DRUM WHEN SPINNING
Sounds like the main drum bearings have gone, if you hold the the drum and can feel up and movement or it sounds noisy or rough when you turn it by hand then it is definately bearings gone.
Unless you know what you are doing ,I would not recommend a D.I.Y. repair.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
Washing machine
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Dec 20, 2007 | Washing Machines
Washing machine-dryer AEg
it could be the drum bearings going
Nov 05, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat W1050 Front Load Washer Logo
147 people viewed this question
Top AEG Washing Machines Experts
shaun taylor
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
