Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Blank screen except for a vertical grey line through the middle
I have a lighty used (2 years old, 50 hours of use max)N2750. When I power it on, the screen is completely blank except for a vertical grey line in the middle. It is completely responseless. I can't toggle between inputs, the remote control does nothing, non of the buttons on the monitor do anything. No PC, no TV, no sound. Just a vertical grey line in the middle. Any suggestions out there? Thanks in advance. Jim
  • 4 more comments
  • Jim minashi Jul 12, 2007
    Thanks for the advise. I guess I'll be performing some minor surgery here shortly. I'll post back if I find something. Thanks again.
  • Jim minashi Feb 01, 2008
    It is a LCD TV. Just like my original post states, there is no picture or sound, just a vertical line, I just closely inspected the vertical line andI found that it is actually made up of 3 lines (red, blue, green) but it still looks like a vertical line going across my monitor from the bottom to the top.
  • Anonymous Mar 09, 2008
    sony 42" wega TV projection under one year old has a line or many lines together that runs right down the middle of the screen
  • joseph john Apr 18, 2008
    my television purt the vertical line on the middle hou can i repair
  • Anonymous May 20, 2008
    Same thing, this is a pretty new tv, and all the sudden yesterday, it blacked out to a small line going through the center...you can tell normal cable is running...you can see a fraction on the channel...what could this be?
  • taxhawaii Nov 28, 2008
    same problem. 2yr old sharp TV that all of a sudden, 2 days ago, when i turned it on it had a vertical line in the middle of a blank screen. Still doesnt go away. was the only solution to change that vertical thing? would it cost more to do that, through a repairman then it would be to just get another tv. it is a 37 inch.thanks.
    Problem Solver:
  • 10 Answers
This is a lcd. there is no yoke. it's a bad panel.
Posted on May 01, 2008
    Problem Solver:
  • 7 Answers
Its a lcd tv , crt tv or dlp projection tv. what is it, i can help fix ur problem..get back, give me more info
Posted on Jan 08, 2008
  • kennyfixall Jan 08, 2008
    get back i can help solve ur problem,
    Genius:
  • 1,074 Answers
Your tv vertical circuit is faulty there are some caps in the vertical section change them, also you should be getting about 30volts on the vertical ic leg 1 out put if that is absent change it also check the vertical yoke winding it could be open.there is also a diode that feeds the voltage from the base of the hot to the primary winding of the flyback check and see if it is open.good luck
Posted on Jul 01, 2007
The horizontal sweep signal to the yoke is bad. Since other problems exist, the problem may be in the IHVT HI voltage transformer area. Check for bad solder around the IHVT pins and yoke plug. I hope this helps. Lee http://www.CrazyComputers.com
Posted on Jun 29, 2007
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
My 52" Vizio LCD (2 yrs old) has power but blank screen
Looks your power supply quit. Get a new one from vizioparts.com might cost a buck and a half,plus an hour of labor, but 52"? deffinetly worth it! Vizio is good on parts. Make sure, have your serial# ready. some sets have been modified within a year, might get a wrong part without ser#.
Take care.
Jan 23, 2010 | Vizio GV52LF 52 in. LCD TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
Dell W5001C 50 in plasma - vertical black line
the y-boards are not the problem. its the e or f board located on the bottom of the panel open the back cover and look at both for potential burn spots around the silicon sealant. if one or r brown, theres your problem. ebay the board number and get it fixed.
Aug 18, 2008 | Dell W5001C 50 in. Plasma HDTV
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
1,014 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
