Question about E-Machines T3985 PC Desktop
Usb ports and digital media manager on emachine t3985 don't work
I've tried every way i possibly can to try and have the usb ports to read any of my cameras or flash drives and my digital media manager doesn't let any type of card be read as well. can someone please help me diagnose the problems.
  • Anonymous Jan 23, 2009
    i tried that and it still doesn't work. i keep getting "USB Device not recognized.
    Scholar:
  • 172 Answers
Can you take the side panel off the pc, the one on the left when pc is viewed from the front.Look for the usb header where the front panel cables from the usb ports plug into. See if the plug is on, loose, try pulling it off to refit and check, come back to me and let me know if you need more help.
Emachine specialists
compdoctor2005@btinternet.com
Posted on Dec 28, 2008
E Machine T3985 has stopped recognizing cameras that it did before
Try using a different USB plug in on your laptop. It's possible you shorted out the one you are using.
Aug 19, 2012 | E-Machines T3985 PC Desktop
Winxp sp3 andwin7 cannot recognized its USB adapter saying that it is an unknown device, i've tried to remove it from device manager and reboot, i also tried to update the driver through windows update...
The easiest way to figure out what is going on is to try the adapter on a different computer. If it is still good it will be detected. Usually when a usb device fails it may be recognized or is recognized only as a usb device but it will not work. You don;t have to install any drivers just to test this on another computer unless you want to make sure it is fully functional. It is also possible that the usb ports on the computer are not working or one isn't. Simpley use on of the other ports.The usb port controller usually operate a pair of usb ports so try all the ports. You may get a problem with one port or pair but rarely all at the same time.
I think you will find that the adapter itself is your problem and will probably need to be replaced.
Sep 15, 2011 | EnGenius EUB-9701EXT2 Pre-802.11n Wireless...
I am trying to transfer pics from my camera to my pc ??? i plugged it in and card is in camera but nothing?? help?
Here are some steps to run through to make sure the camera works as you'd expect it:
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Hope this helps.
May 05, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
Sony mp3 player won't charge using any usb port in my computer. Mp3 port is loose...took apart, don't see y it's loose
Possible reason could be frequent use would have damaged the port connectivity, If there is another usb port use them or else you can clean them to se it this works. if not try to fix a USB extender which can be procured from any PC harware shop that might sometimes give a good connection , thre after do not remove this connector but use the extender port.Check to also see if your USB drivers can be reinstalled, check though the device manager/ ports. Helpful? Good day.
Jul 05, 2010 | Sony NW-A605 (512MB) MP3 Player
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Hi, i was wondering how to burn dvd's on my emachine t3985? when i bought the computer the owners manual or users guide never showed me how to burn them. also, my digital media manager and my usb ports...
A dvd is burned the same way you burn a cd. Gather the data you wish to burn, then open your software, drag the data in there and press the burn button. Often you will find Nero or Roxio software installed on your machine, you can also use Windows Media Player.
Dec 28, 2008 | E-Machines T3985 PC Desktop
E-Machines T3985 PC Desktop Logo
989 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
