Question about Hotpoint Washing Machines
Hotpoint Aquarius 1200 Washer Dryer not drying.
I've got a Hotpoint Aquarius 1200 Washer Dryer with a problem drying. After the spin everything is as dry as you'd expect, but when I then try drying it seems to get wetter.... in fact it comes out steaming !! so it's still getting hot & therefore the heating/drying elements are ok. I've checked/cleaned the outlet pipes/hoses so think they're ok. Could it be the waste water pump ? Any easy way to check before I replace ? It can only be a temporary issue as it seems to drain ok during the wash cycle.
  • mike708 Dec 28, 2008
    thx. forgot to say that there were remains of what looked like some sort of plastic washer/seal stuck in the outlet pipe... about 3 ins. diameter. Assumed it was out of someones pocket but may have actually been part of the machine. Does such a seal normally reside in the vicinity of the 3way water inlet valve & would the absence of such a seal cause the excessive water coming in during drying ?
    Scholar:
  • 86 Answers
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Posted on Dec 28, 2008
  • Kris Seymour Dec 28, 2008
    Glad you found something? If the item you found in the waste hose is the same size as the waste hose it could of been casuing a gate like effect in the hose stopping the water from emptying quick enough. Give it a go now see what happens. The restricter is roughly the size of a large pea. And it would not get washed into the machine it would only stay in the inlet hose!
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Washer WF320 1200
It could be that the drum is coming loose and a bolt requires tightening. I would suggest that you cease use until you get this fixed. Yell.com will provide you with choice of qualified engineers who can assess and repair.
Aug 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius wd420 1200 spin
Flushing all button something wrong inside the machine ./The mahcine while flushing unplug it , wait for 30 minutes , Plug again observe ?/if still flushing the motor stuck/ if stop flushing the machine reseting.
Jan 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
216 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
