Question about Gateway GT5220 PC Desktop
LED lights I unhooked the 3 wires from the bezel ,led light,power and hdd now i can't hook them up again.
    Genius:
  • 1,913 Answers
Hi
u can see in corner of mother bord for that wire pin. also u can find the map.and aslom u can seee words in small word like HDD , pwr,then fix it.
Posted on Dec 28, 2008
My 1999 Honda shadow 750cc won't start
Ok, been awhile since I played with a Honda, but I believe in the KISS method.
#1 go buy a cheap $10 meter at harbor freight, Menards, Home Depot, Lowes, etc, etc. You can't just look at a fuse and say it's good, been there done that...LOL
#2 There used to be a fuse in the headlight bucket, check to see.
#3 real simple, did you leave your KILL switch off??? If not the check voltage to kill switch, make sure you have power coming out.
#4 check the ignition wire for the starter, when key is in on position or (start) position, make sure you have voltage. If you have power, follow it to your starter leads and kill switch.
#5 check voltage at your coils, Check for voltage coming out of coils. Just because you may or may not have spark, doesn't mean you have enough to start bike.
When you hooked in the LED's you either shorted wires to blow a fuse, over loaded a wire and possibly burned it in 2. Or you dislodged a connection someplace. Go back over everything you did again, and go buy a meter.
May 22, 2017 | Honda Motorcycles
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
Hook up the power ,hdd led,power led, power switch on micro-star ms 7529
Hello Randy, the terminals are located near the SATA ports. read your motherboard labels near it and you'll find the connectors, its very basic, you can figure it out. plus signs are green for the power led and orange for the HDD. read the wire connector of your PC casing.
Jan 02, 2014 | Computers & Internet
How to hook up the face plate of a emachine w3400 Wich includes 3 wires 1 power butten and 2 led lights
Look at the pinout of the Front Panel header, of the eMachine W3400's motherboard.
The plastic front of the computer is the Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel connect to,
is the Front Panel header.
The motherboard for an eMachines W3400 desktop computer is an MSI ms-7145
(Micro Star International)
Orient the motherboard in your view so that we are both looking at it the same way.
Processor to the Top, Ram Memory slots to the Right, white PCI slots (3) to the Bottom.
JFP1 is the Front Panel header.
(Junction Front Panel 1)
JFP1 is on the Bottom Right corner. There are two columns of pins arranged vertically.
(The JFP1 header runs parallel to the Right side of the motherboard)
The Left side column of the JFP1 header is numbered Odd.
Starting at the Top and going Down, the pins are numbered;
1, 3, 5, 7, and 9
The Right side column is numbered Even.
Starting at the Top and going Down, the pins are numbered:
2, 4, 6, and 8.
There is NO Pin 10
A) Pins 1 and 3 are for the HarDDrive Activity LED light. (HDD)
If the LED light is dim will operating switch the wires around
B) Pins 5 and 7 are for the Reset switch. (Reset button)
> IF Used
C) Pin 9 is Not used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light (If dim switch the wires around)
E) Pins 6 and 8 are for the Power On switch. (Power On button)
Trace the wires back to the Power On switch. Even if it means temporarily removing part of the Front Panel to see.
Same with the LED lights.
See which wires go to the Power On LED, and HDD Activity LED. (Harddrive Activity LED)
Follow the 3 wires, and tell me where they go to on the Front Panel.
USB port?
Memory Card Reader?
Firewire port? (a1394)
Nov 27, 2010 | AMD eMachines Desktop System w/ 17'' CRT...
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Sep 19, 2009 | E-Machines T6520 PC Desktop
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
I unhooked the 3 wires from the bezel, led light,power and hdd i can't figure out hoe to hook them up again.
see on the mother board you will find the labels there near the righthandside bottom corner there is front panel configuration
connect the pins to the exact pins
Dec 28, 2008 | Gateway GT5220 PC Desktop
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Led light
The light that used to stay on all the time is most likly the Power light(LED) The light that used to flash when you were using the computer is the  HddLED(Hard disk drive Light Emitting Diode) If you mixed them up it wil likly only light the wrong light.    I hope this helps.  If you wish to be sure you may be able to download the owners manual  the manufacture ?
Oct 02, 2008 | Gateway GT5220 PC Desktop
Gateway GT5220 PC Desktop Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
