Question about Gateway GT5220 PC Desktop
I unhooked the 3 wires from the bezel, led light,power and hdd i can't figure out hoe to hook them up again.
    Master:
  • 569 Answers
See on the mother board you will find the labels there near the righthandside bottom corner there is front panel configuration
connect the pins to the exact pins
Posted on Dec 28, 2008
My 1999 Honda shadow 750cc won't start
Ok, been awhile since I played with a Honda, but I believe in the KISS method.
#1 go buy a cheap $10 meter at harbor freight, Menards, Home Depot, Lowes, etc, etc. You can't just look at a fuse and say it's good, been there done that...LOL
#2 There used to be a fuse in the headlight bucket, check to see.
#3 real simple, did you leave your KILL switch off??? If not the check voltage to kill switch, make sure you have power coming out.
#4 check the ignition wire for the starter, when key is in on position or (start) position, make sure you have voltage. If you have power, follow it to your starter leads and kill switch.
#5 check voltage at your coils, Check for voltage coming out of coils. Just because you may or may not have spark, doesn't mean you have enough to start bike.
When you hooked in the LED's you either shorted wires to blow a fuse, over loaded a wire and possibly burned it in 2. Or you dislodged a connection someplace. Go back over everything you did again, and go buy a meter.
May 22, 2017 | Honda Motorcycles
Hook up the power ,hdd led,power led, power switch on micro-star ms 7529
Hello Randy, the terminals are located near the SATA ports. read your motherboard labels near it and you'll find the connectors, its very basic, you can figure it out. plus signs are green for the power led and orange for the HDD. read the wire connector of your PC casing.
Jan 02, 2014 | Computers & Internet
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
LED lights
hi
u can see in corner of mother bord for that wire pin. also u can find the map.and aslom u can seee words in small word like HDD , pwr,then fix it.
Dec 28, 2008 | Gateway GT5220 PC Desktop
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Led light
The light that used to stay on all the time is most likly the Power light(LED) The light that used to flash when you were using the computer is the  HddLED(Hard disk drive Light Emitting Diode) If you mixed them up it wil likly only light the wrong light.    I hope this helps.  If you wish to be sure you may be able to download the owners manual  the manufacture ?
Oct 02, 2008 | Gateway GT5220 PC Desktop
T3624 MB someone pulled off the 3 wire pairs to the front bezel. What's the pin out for the 2 leds & power on??
According to the internet, your computer has an Intel 845GV chipset motherboard. Intel tends to use a generic pattern for connecting the front panel connectors. A description can be found on intel's site.
If this doesn't solve your problem, comment back with the motherboard model number. Look on the board, it should be printed somewhere, and it should start with D845GV...something something...
Steven
Sep 17, 2008 | E-Machines (308714) Motherboard
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
Trying to hook the motherboard back in
it varys on each machine , but on the mother board their is a group of pins stickin out one or 2 have jumpers leave them alone! go to the pins left bare their is minenute abreviations next to the pins they will giv you an idea of what 2 do ,also look for colour coding.
Jan 17, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
Gateway GT5220 PC Desktop Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
