Webcam microphone problem
Hi I have a problem with getting sound on skype.I have a webcam with a built in microphone.When it is all set up and we can see and hear who we are talking to they cannot hear us.Clicking enable microphone does not work!!
  • 13,433 Answers
Hi the microphone on the webcam probably isn't working or its turned off or volume is muted / low. I would suggest you get a 2-5 usd cheap mic from a local store and plug it into your sound card mic plug. Problem solved.
Posted on Dec 28, 2008
  • Ekse Dec 28, 2008
    Also check skype settings that its using the webcam microphone instead of the sound cards microphone.
Webcam not detected on skype
Hi Shane,
Thank you for contacting fixya.
Try to install latest webcam driver downloaded directly from laptop manufacturers website. it will help you to get your webcam on skype.
Feb 09, 2014 | A4tech PK-635 Webcam
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Can I use a plug in microphone to use skype on a Dell precision M70
I haven't set up Skype before, but it seems quite reasonable that if the Sound control panel is set to use the external microphone, that would work. Have you checked to see if the sound input is set to an internal microphone built into the laptop, or a line-level input? That could be your problem, especially if no such microphone is present.
Nov 25, 2011 | Computers & Internet
I am trying to skype with a friend but my built in webcam in my EeePC laptop isnt working... skype says it can not reconize it!): help me??
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
Apr 13, 2011 | Computers & Internet
Skype shows "you microphone is really quiet"
Set up Audio example
Laptop x webcam/mic x Vista x Skype
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Start Skype.
On the Tools menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Set your speakers as default.
Select your webcam as the default microphone.
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
Select your webcam as the default.
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Dec 16, 2009 | Genius VideoCAM Messenger Webcam
I have sound and I can see myself but the person I talk with can't see me but I see them I am using Skype.com to communicate with friends
Before you can use your webcam in any chat program you have to configure it to that program
Start Skype.
On the Tools menu, click Options.
In the navigation pane of the Skype Options window, click Audio Settings.
Select your webcam as the default microphone. (If it has a built-in mic)
Click 'Save'
Click 'Save'.
Test webcam by making a Skype test call.
Oct 18, 2009 | HP Computers & Internet
Skype doesn't read my camera
Start Skype.
Click Save.
Sep 23, 2009 | Logitech QuickCam Webcam
I cannot be heard on Skype using the built-in Microphone on my...
Make sure that you have the Microphone pointed to your webcam within SKYPE. I know that with Ventrillo you need to set it up to see the device within the program. I would look for options within Skype.
Jul 17, 2009 | Microsoft LifeCam VX-1000 Personal Web...
Problem with sound through pleo cam II with skype
What it sounds like is that the Audio Setting has not been set to that mike. To do so, go to tools, then Options, and click on Audio Settings. Go to the Microphone drop down and select the pleo camera microphone. Then on the bottom of the page, SAVE and it should be good to go.
Hope this will solve your problem. Bud
Jan 01, 2009 | Computers & Internet
No sound on Skype
No sound at all on skype. although microphone is ok
Nov 17, 2008 | Skype IM
Computers & Internet Logo
Alun Cox
David Payne
David Payne
