Problems with sounds
I remove axidentaly sounds,I xant to install it
    Genius:
  • 1,913 Answers
Pls give me your sound card 's company name and model number.
Posted on Dec 28, 2008
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
Yellow registration problems on xante 502
clean all the registration sensors on the imaging drums and at the fuser end (there are 3 under a shifting piece of white plastic on the left side after transfer belt is removed.
May 15, 2014 | Xante Ilumina Digital Color Press Printer
My Xante Accel-a-Writer is not communicating with my macmini. I understand that OSX 10.6 doesn't support appletalk, and have configured the xante as an LPD printer and entered its IP address. The mac...
First, I would recommend that you connect the Xante Accel-a-Writer to a Windows OS computer (xp/vista). Observe if it will function perfectly. This will determine whether you are doing something wrong or if the problem is from the Xante Accel-a-Writer or if they don't support each other.
You can test the Xante Accel-a-Writer on a friends windows OS computer if you don't have one.
Let me know the out come so that I can direct you further.
Good luck.
Oct 19, 2010 | Office Equipment & Supplies
How to install xante ilumina drum units?
When you unpack the drum it has like a white nylon and three orange plastics. Remove the three plastics(tapes are holding the plastics) and at the end remove the white plastic it has an arrow. Do not touch the drum. Make sure not to much light hits the drum. You have four drums remember to sit correctly the drum and to its correct position.
Jul 02, 2009 | Xante Ilumina Digital Color Press Printer
Will Accel-a-writer 4n work running Leopard 10.5.6?
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Jan 02, 2009 | Xante Accel-a-Writer 4N Laser Printer
Paper Tray Oki /Xante ?
It sounds as if maybe the trays are not configured in your software. Access the printer driver and make sure that the additional trays are enabled. Under the Device Setting tabs, if on PC, available trays, ensure that you have the correct number of available trays selected.
??? If that doesn't work, you may want to check back with Xante to make absolutely sure they do not have the trays in question.
p/n 250-100075
Jun 19, 2008 | Xante CL30 HSE Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
Paper Jam will not clear
  1. I have identical problem with the Xante 1200.
Mar 14, 2008 | Xante AW 1200 Laser Printer
Unable to get Xante printer to work
When I send a job to the printer via Ethernet, nothing happens on the printer. I only get a solid red light. Why?
This is an indication of a media size mismatch. Make sure that the correct media size is set on the tray to which you are printing, and try the job again.
(from http://www.xante.com/support/aw1200/)
John
(Xante ASA)
Nov 19, 2007 | Xante AW 1200 Laser Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
