Question about HP vs15 15"LCD Flat Panel Monitor
Hp LCD Monitors
I have a good running hp vs15 LCD monitor and a broken hp vs17x that has a power suppy problem. Do you know if I was to switch out the main boards would it work, I mean fron a 15 inch to a 17 inch CRT? I have also replace a transistor in the 17 inch but it must be a bad main board. so I was wondering if the 15 inch main borad would support the 17 inch CRT?
You probably don't know unless you tried it! And thats me too! Thank Mitchell
3 Suggested Answers
SOURCE: I need Tech manuals/Schematics for LCD monitors
Hello. what is your problem with them?
Posted on Oct 30, 2011
yutianyunren
  • 848 Answers
I need Tech manuals/Schematics for LCD monitors Compaq pe1231 p9622a 17 inch and HP vs15 MDL# hstnd-2l04 LCD monitors? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
490421200100R QLIF 041 HP 790421200A00R Power Supply Backlight Inverter
Posted on Dec 11, 2014
Power on off problem
3 capacitors are probably bulged pn the monitor motherboard. I just fix my vs17x hp monitor, but now I have another problem. but thats your problem, the 3 bad caps in the monitor. search it up.
Jan 13, 2011 | HP w1907 LCD Monitor
Vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor: you mash the power button and the light will come ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
No power when u plug in an turn on HP vs15 15 in. Flat Panel LCD Monitor.can u tell me how to open it up so i can check the switch
You need thin flat blade screw driver to crack open the case, it is almost the same as VS19, more likely to havebad caps with bulging tops, see pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Mar 10, 2010 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 no problem
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the power button connections if loose/broken. regards
May 15, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
Is it safe or unsafe to try to repair on your own?
You have 6 screws 4 hold the base on and 2 on the backside of speakers. From their you can open it.
If you still have the monitor that is.
Oct 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
Black horizontal line
The LC display is bad. The monitor will have to be replaced.
Jun 24, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
