Advent 4489 USB Ports
Hello Dean, I believe you have an Advent 4489 Atom512. Could you tell me how many USB ports there are on an Advent 4489 please. Thank you in advance.
  • 3 Answers
Hi. there are three ports. 2 on the left and 1 on the right
Posted on Dec 28, 2008
Wher are the USB ports on Advent DT1308
Advent Advance DT1308 Desktop PC?
http://www.pcpro.co.uk/reviews/desktops/370084/advent-dt1308
Look at the Back of your Advent computer tower.
Look at the lower left.
This rectangular area is the I/O area.
Input/Output area.
This is where Input and Output devices are attached.
Look at the Purple round PS/2 port all the way at the right bottom.
It's where the Keyboard plugs in.
Right above it are four USB ports.
http://en.wikipedia.org/wiki/USB
There are several styles of USB ports. This style is a USB female type A,
http://en.wikipedia.org/wiki/File:USB.svg
(Standard A )
According to the review (Specs tab), there is supposed to be two USB ports in the Front. (Front Panel)
I do not see them.
Could be behind a door that swings open.
Looking at the Side View, with the Side Panel of the computer case removed, the USB cables going to these front ports, are going towards the bottom/front.
Regards,
joecoolvette
Apr 25, 2012 | Computers & Internet
I have a advent 7302 laptop the usb ports do not reconise anything pluged into them and when i plug a device in the mouse pad locks the cursa
Try and re-install the USB drivers for the Mainboard, Any problems with external devices in USB ports could be due to a lack of power (or low power ) on the ports. I hope this helps point you in the right direction.
Jan 22, 2012 | Advent Computers & Internet
The power supply to my Kensington SD100 Universal Docking Station has died. Firstly, do I need it for anything? What can I replace it with?
Hi Andy,
I believe the main purpose why you are using a docking station is to have more ports available for your portable system. If this is correct, you can use any type of USB hub to extend the number of USB ports available for your portable system. Unfortunately, you cannot purchase a docking station now a days since the product has been discontinued by all manufacturers since the advent of other devices such as this USB hub I am recommending you.
I do hope this information helps.
Jul 07, 2011 | Computers & Internet
My machine is a 2007 Advent 7201 Laptop which is solidly built and performs above expectation, but as of last week it can't recognise any device connected to its usb ports (printers, mobile phones cameras...
It may be that the usb ports have died but before we get carried away lets see if we can check some other things first.
1. disconnect "ALL" usb devices
2. shut down and re start your laptop
3. double check in your hardware control panel that there are no exclamation marks next to any hardware
4 if there are any problems list in your hardware fix those first
5. if you don't have any usb hardware listed go get the latest drivers from the manufacturer and install them.
6 If you don't have any hardware listed and cant install any drivers for them then yes it is more than possible that the usb ports are dead
This could go as far as a new motherboard to fix but only a qualified laptop specialist could give you the answer to that and certainly not over the internet.
If though you got this far without too many problems
1. insert only a pen drive into one of the usb ports
If it shows up then move it to another port until you have checked all ports. If all is good then it is quite possible that you were overloading the ports !
This is common in laptops and my suggestion would be to get a decent quality usb hub that has its OWN POWER SUPPLY.
Anything that you can plug into that will reduce the load on your laptop ports and increase the life of those too.
Note that some hardware does not like hubs.
If this post was useful please click below
Aug 12, 2009 | Advent Computers & Internet
Sata drive cable positons on motherboard
The plug in sata ports do not matter for order unless you are plugging into ports reserved for RAID. Check your motherboard manual to see if any ports are reserved for this setup. If so change any cables out goint to those ports. You will also need to enter bios and make sure SATA is enabled in your settings. Once you have done this you should be able to boot and your drives will be auto detected. Hope this helps.
Jun 03, 2009 | Foxconn G33M Socket LGA775 motherboard
Need to switch internet function on advent 4489
prees the funtion key ( blue Fn, bottom left ) and F11.
you may have to do this every time you turn on your netbook.
Jan 04, 2009 | Recoton Advent Advent Q2035A 20" TV
Advent 4489 bluetooth
it does not have built in Bluetooth, I took mine back to PC World stood about for 1.5 hours to be told it did not have it. This was December 31st they are still advertising this model as having Bluetooth ! Offered me my money back or bluetooth stick. Wrote to customer services waste of time said Shop manager had to sort out, been going round in circle since.
Dec 29, 2008 | Recoton Advent Advent Q2035A 20" TV
Webcam for Advent 4489?
http://www.a4tech.com/ennew/driver/CameraA.zip - driver can be found here
Dec 26, 2008 | A4tech PK5
Advent 4489 can it get microsoft word
No I believe it has office app' but not word,you can load MS word using extenal drive or get pc repair shop to do it(£15-20) tho' due to memory you best uninstall office.
Dec 10, 2008 | Recoton Advent Advent Q2035A 20" TV
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
