Question about Pioneer TS-W251R Car Subwoofer
One or two
I've got a 460 watt amp, would my system sound better if i had one 10 hooked up or two
    Problem Solver:
  • 12 Answers
IMO 2 would be best. A good 10" woofer will give you good all round bass but wont rock your block off. The bigger your woofers the more low end base you will be able to produce so a 10" is a good balance between low end and thumpy bass for a full sounding system. The type of box you decide on encosing the woofers in will also affect your sounds. Consult your local car audio experts for more info. Good Luck
Posted on Apr 24, 2007
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Recomended amplifier for tr 2800
I've had a set of TR-2800s for about 7 years, I started with a kenwood stereo amp but graduated to a Yamaha 5.1 system in 2008, any system with 100 watts or better output on the main channels is fine, You can't blow these things without 400 or more watts.
Aug 03, 2010 | Theater Research TR-2800 Main / Stereo...
Capacitor not working properly
the power side has to be in line with the battery power side! The ground side to ground! The power that ran from battery (fused) to the amp power is used and cap is tapped in line, on that power lead! that way your amp gets power with cap charging and stable voltage to amp! taking stress off your charging system and better sound! good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Jun 09, 2017 | Pyle BZDBP212 Car Subwoofer
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
My blaupunkt gta 460 goes into protection
Check the speakers wires for a wrong connection,check the speakers maybe they are not support the power of the amplifier,good luck
Jun 05, 2009 | Blaupunkt GTA 460 4 Channel Amplifier 800...
220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
Apr 03, 2009 | Car Audio & Video
Amp hook up
To do it safely, you need to fully understand everything about the system. It would take too much to explain everything here. If you're really interested in doing this properly, read through the following site. Read the 'Fuses' page twice. It will help prevent an electrical fire.
Basic Car Audio Electronics
Aug 02, 2008 | Car Audio & Video
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Pioneer TS-W251R Car Subwoofer Logo
61 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
