Question about Nintendo Wii Console
Wii can not read disc
Disc inserted but will not read.
  • 3 more comments
  • mandym40 Dec 28, 2008
    my wii will not detect or read any discs
  • rozenberg Dec 28, 2008
    I have a Wii Console with a modchip. It works for 3 weeks perfect. Now it can read the the original disc and also the copy disc. Can anyone help me
    THNKX
    Bird
    I have the same problem with copied games and also with the original games. A few days ago i didn't have any problem. What is the solution fore this problem.
  • jayandjake Jan 02, 2009
    My wii wont work anymore after i got it chipped, it worked fine then i put it away and two days later i take it out because i have just burnt a game on to a disk and was waiting to try it and it would nt work and wouldnt read any of the other games... it might be the chip itself... hmmm i wonder...
  • Anonymous Apr 10, 2009
    i got this new wii game on da internet nd when i put it in it never plays!! so can any body tell me wat does it say on da manual or any help at all wud b gr8!!!!!!!!!!!!THANKS!!!!!!!!!!!!!!!!!!!
  • 33 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
120
Posted on Mar 22, 2009
  • 26 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm you that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 21, 2009
    Problem Solver:
  • 5 Answers
Is this a copied game as you can get this if it is not burnt correctly.
If not and all your other games work, give the disc clean and try again. If this still does not work, take it back. Now and again you can get faulty discs.
Hope this helps.
Posted on Dec 28, 2008
Wii turns on but will not read any disc.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Hope this will help...
May 27, 2010 | Nintendo Wii Console
Unable to read the game disc in the Wii
store.richsxparts.com
May 26, 2010 | Nintendo Wii Console
Games discs purchased in the USA do not work on the UK model? Message on screen "could not read Disc"
The Wii console is designed to only recognize the disc in that region.
If you insert a disc from another region, the Wii can't read it.
You live in the UK, for example. If you insert discs that aren't purchased in the UK (like the USA), the Wii can't read it.
Apr 24, 2010 | Nintendo Wii Console
Cannot read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide...
Mar 29, 2009 | Nintendo Wii Console
Will not read wi disc
well you can get a cleaner wii thing cause your wii might have dust in it so you can try that there around $20-$30 each in aus so that should work
Jan 15, 2009 | Nintendo Wii Console
Wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 14, 2008 | Nintendo Wii Console
Won't read any disc
Nov 16, 2008 | Nintendo Wii Console
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
The Wii will not read the disc
"Unable to read disc" error happened today for the first time on my Wii. I positioned it horizontally and tapped on the top while it was reading a disc and it started the game. This temporary solution might bring you immediate, but probably not long lasting satisfaction.
Sep 12, 2008 | Nintendo Wii Console
To install wii fit
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
    If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Aug 13, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
131 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
