For some reason the microsoft fax in win XP does not work and I can't re install it from control panel?
  • 1 more comment
  • MottiMash Dec 28, 2008
    the fax used to work properly for long time. some weeks ago it stop working with the message that another program uses the fax (maybe Lexmark fax machune I have!
    I removed all fax programs from the computer and try to reinstall the Microsoft fax. but it doesn't work. the modem etc. all is correct
    thank you
  • Edward Morgan
    Edward Morgan May 11, 2010
    Is the MS Fax software still installed?
  • Thomas F. Schneider May 11, 2010
    Do you have the fax driver and modem installed?
    Has it worked in the past and this is a new problem?
    Is the modem working on the telephone line?
  • 86 Answers
If you have windows xp you can do it from comtrol pannel in add/remove programs on left side it says add or remove windows components. It can be installed from there. If you have a different windows you may have to use the original installation disk and when it comes up press repair installation it will reinstall what you are looking for.
Posted on Nov 06, 2009
My updated driver of Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller cannot be downloaded on my Windows XP version 7 system. The message says it has not passed Windows Logo testing to verify its...
win xp is no longer supported by Microsoft so you will not get it to work
Likewise win 7 is no longer supported by Microsoft so you could be lucky there but I doubt it
win 10 is the one now being supported by Microsoft so you mat have to install win 10 to get it to work
Dec 21, 2017 | Marvell Yukon 88E8056 PCI-E Gigabit...
How the remove the genuine microsoft software?
If you just need to install a new OS ( win 7 ? ) , all you have to do is to insert the install disc and Windows will do the job , deleting Win XP at the same time . Don' t forget to back up your data and drivers before proceeding .
Best regards,
fanaudi .
Aug 05, 2011 | Microsoft Windows XP Professional for PC
Win xp heberw to English verian how can i read English.everything is program heberw. so i need to English translat.im trying but nothing
Hi there !
You have to go to language or regional setting to change your language setting. Go to control panel and choose language and regional and try to update it by installing desired language using internet connection.
I hope it helps you.
Jan 21, 2011 | ASUS Eee 4G Notebook
Dell Latitude D800-Win XP- My Dvd/rw wont write
Because you lost two devices, the DVD and the wireless mini card, I believe your problem is a drivers issue.
You should make sure you do not have any Malware that is removing these drivers.
If you have access to the Internet download and install Malwarebytes. It has a quick scan that will ID any infections.
Then get the newest drivers for those two devices from Dell's support site.
Before you install the drivers, remove those devices in Control Panel.
Mar 20, 2010 | Dell Latitude D800 Notebook
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Cannot install fax services in xp. running xp
This might help:
http://support.microsoft.com/kb/306550
Are you using the correct CD to your Windows version?!
Sep 17, 2009 | Microsoft Windows Xp Home Edition Sp2...
How to install hp laserjet p1505n network printer in windows 98
I can not find a win 98 driver for your printer on the HP website. DO yu have the instalation disk that was writen for win 98? If not try installing the printer through  the control panel. Either printers/fax or through install new hardware.The first being the preference. Some of the win OSs have printr drivers already installed.
If this does not work out, then the printer has no drivr available for that version of windows and you ewither have to upgrade to Xp or use a different printer which has a driver for win 98.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us〈=en&product=3435671&
Jan 02, 2009 | Office Equipment & Supplies
Hidden Program
In Windows 98 the MS fax client is installed as part of the windows messaging package and uses a mapi client like exchange client, outlook, or windows messaging to work. Try 'add/remove software' in the control panel and see if you can unistall windows messaging. If you have the win 98 install cd, there is a file called wmw-fax.txt in the tools/oldwin95/message/us folder. you might find the information in there.
Apr 07, 2008 | Microsoft Windows XP Professional With...
Printer sharing. how to do it?
In Win XP & presuming you have a network set up:
Navigate via :
Start - Control Panel - Printers and Other Hardware - View Installed Printers & Faxes.
Click on the printer icon you want to share.
In the panel on the left (Printer tasks) click on "Share this Printer"
It worked for me!
Dec 04, 2007 | Epson Aculaser C1100 Printer
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
