Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Starter cord Hi Boscia, Appreciate if you could you give me instructions on how I could replace the starter cord on my own? Thanks! Edwin
  • ehsling Dec 28, 2008
    Thanks, mate! I'll try to fix it this afternoon. Cheers, Ed
  • 163 Answers
Sure, no problem. this is the easiest way:
first remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. then feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt it a little and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, i suggest replacing the whole starter assembly because the coil spring is extremely difficult to replace by itself. thanks for using fixya.com. if you have any other qestions or need further assistance, just let me know and i'll be happy you. happy holidays
Posted on Dec 28, 2008
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
Try to start riding mower. it just clicks. I've got 12V to the starter. I thought starter was done so replaced it and no luck> still just clicks. I'd appreciate some help. OHVB 15hp...
hi jerry396
you say you replaced the starter - do you mean starter solenoid or starter motor ?
if you run battery jump lead from bat + to s/motor terminal and connect neg jumper lead to engine earth and other end of neg jump lead to negative bat post with key on - will the engine crank over easily and start - if so your starter motor is good if not problem is elsewhere.
check your battery - it could be a faulty battery , and earths, also 12 must be present @ solenoid from the key switch in start mode and check that the solenoid has a good ground
check the starter solenoid as well - it could have burned contacts adding very high resistance to starter cable , also check your starter cable - for resistance - it should have no more than 0.3 or 0.4 ohms
make sure all interlocks are operating - ie clutch brake, cutter attachment , nuetral switch , seat switch ,
cheers hope it helps
pauly46
May 20, 2011 | Garden
The starter pullstring has come out
Hi and welcome to FixYa. This is not a simple cord replacement job. There are youtube videos on how to change the rewind starter cord. Use this search link: http://www.google.com/search?q=Starter%20rewind%20Cord%20change&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&ie=UTF-8&tbo=u&tbs=vid:1&source=og&sa=N&hl=en&tab=wv
Or this one for just images:
http://www.google.com/images?q=Starter%20rewind%20Cord%20change&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&hl=en&ie=UTF-8&source=og&sa=N&tab=vi
The key is you have to pre-wind the spring before replacing the rope.
Thanks for choosing FixYa.
Kelly
Aug 18, 2010 | Garden
Starter cord won't rewind
The starter cord is spring loaded. When the spring breaks your cord won't rewind. Usually the whole starter cord assembly is easily replaced and readily available at your local gardening goods retailer. They might even install it for you for a nominal fee. I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Nov 05, 2009 | Sewing Machines
Not working = power rear window, power antenna, starter
it looks like the starter is bad, install a new one. the antenna gear is broken, needs to be replaced and you need to check the rear hatch for any obstructions
Apr 21, 2009 | 1999 Toyota 4Runner
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
STARTER FOR 04 TOYOTA COROLLA
First, turn the key switch to LOCK. Disconnect the battery and wait a few minutes to make sure the airbag is disarmed. Remove the engine cover panels from below the engine. If you need more room, consider removing the air cleaner, upper radiator support, battery and tray and the coolant reservoir and hose.
Remove the starter wires then the starter. Pay attention to which bolt goes to which hole as they are different lengths. Putting it back together should be self explanatory. Good luck!
Please ask if you have any more questions. If this was helpful, please give me a good rating.
Aug 19, 2008 | 2004 Toyota Corolla
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
256 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
