My lennox heating system will not kick on when the temp drops and I have to manually set it every time....what to do?? Im freezing
  • polarcub Dec 28, 2008
    Thanks skeeter140 for that info. However, I found out that I hadn't programmed correctly to set for the right temp throughout the day and night. Thank goodness that was the problem.
  • belltoo Jan 26, 2009
    we have battled the Lenox furnace for years. Several pro's have came out and tightened cleaned and one even changed the thermostat. It work ok for a week may be two and then it want come on. At first fault switching it on and off or running the thermostat setting below and above the extremes made it come on, after a while you get nothing. A few years ago I the same problem and I changed out the spark plug wire and it fixed it. Last year I have the pro come out and he was suppose to have done that same thing and hopefully avoid the hassle during the winter, don't remember last winter but this winter the same old junk. I guess Lenox pulse high efficient units do save me money??? But it a cold cost.
  • 306 Answers
Sounds like your t-stat is failing you. Here is a test you can do. Take the front cover off. Locate the R terminal and the W terminal. Get your self a short piece of wire small diameter say 18 gauge. Now take your wire and jump across the two terminals hold them there and if you hear your furnace kick on then the t-stat is bad. let me know what you find out. ken
Posted on Dec 28, 2008
  • Ken Bledsoe Dec 28, 2008
    Well at least it was the t-stat can you pull your rating as it down grades my overall ratings. You don't have to put any rating on me as you found the problem on your own. thanks ken
  • Ken Bledsoe Jun 01, 2009
    I guess you don't read your post much.
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
Lennox troubleshooting
Your control may a defected relay to the blower under heating mode. If that is the case you will need a new control board or replay.
Feb 05, 2014 | Heating & Cooling
Lennox pulse 21 startup issues .does not engage fan and complete heat cycle every time .
Have seen a rash of faulty blower time delays in lennox equipment. Lennox has a recall on one currently, not sure if your system is effected but it can be bypassed if in fact the problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 23, 2017 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Problems for months, now the heat won't kick on at all
First thing to do is turn off unit at switch. Then dissconnect all t'stat wires from the thermostat. Put the red wire and the white wire together.
If it goes on then you may have not set the thermostat correctly. I use a digital one from Menards made by Honeywell it cost $18.. But if it does not light then check to see if you have 24v to coming out of the transformer. You need a meter to troubleshoot this one!
Mar 20, 2010 | Heating & Cooling
Lennox merit series furnace is not kicking on until house is 8 to 10 degrees colder then set thermostat
I have the same issue with a G21Q4-5-100-1 model lennox. House drops 8 - 10 degrees. I have 3 thermostats and all react the same way. I was told by service tech that the Ignition Coontrol Module is bad and acting intermittanely. ???
Jan 31, 2010 | Dayton Gas Furnace Heater
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Nov 22, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Heating & Cooling Logo
290 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
