Question about Microsoft Windows XP Professional
BOOT.INI deleted. How to re-create this file?
I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ .
I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like C:\,D:\,......I:\), considering it as virus file. It's location is X:\boot.ini by default. Is that file was virus?
After that incidence, During the every booting my computer tells me:
Invalid BOOT.INI file
Booting from C:\WINDOWS\
and starts the XP operating System automatically without asking for Server 2003.
There is no good guide for this situation on the internet.
The problem is that i dont have my xp cd so i cant get it
from there!!!
So how can i get this file back??
  • sandeepks9 Apr 22, 2009
    my computer shows the message that cnnot find boot .ini
    my comp works ok after that
    but i need to solve this
    New Friend:
  • 12 Answers
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Please rate this if you found this answer helpful. :)
Posted on Dec 28, 2008
3 Suggested Answers
SOURCE: Hello, I have 2 Operating
Solution:
i)  I understand what ru trying to say, I'm afraid that iam not providing u with the right solution,                 however  would try my level best:
    a boot.ini file   contains this text for Windows XP;
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
so i want u type this text exactly in an note pad and save it as boot.ini and copy it from where you detled it.....hope so it works....
try making some changes to it(so that it will be Microsoft Windows 2003 server.....as it is the text for Microsfot Windows XP Professional)
note(imp): here "noexecute=optin /fastdetect "  comes next to the "Microsoft Windows XP                                 Professsional" which is above it....
                            (OR)
when logon into Windows XP go to start button----->Click on Run------>type msconfig in text box----->
highlight BOOT.ini, you will see the above text ......
acdr
  • 1913 Answers
SOURCE: BOOT.INI deleted. How to re-create this file?
type in run "cmd" then presss enter then type "bootcfg /?" it gives u some help .
I have 2 HDD's in my PC - both with Win XP Prop
Boot.ini is correct, but looks default is booting from Disk2 and partition 1 which is your G:\ 500 GB.
Try Copying boot.ini from c:\boot.ini to g:\boot.ini It might help
In your example I see missing "\" after partition(1), may be typing mistake, but in real time can generate error.
You boot.ini looks exactly same in both drive c:\ & G:\
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(2)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="GUY DRIVE XP Professional" /noexecute=optin /fastdetect
Note: boot.ini will be hidden and readonly file. You need to unhide the file and remote the read only option and then only you will be able to save the boot.ini file
Hope this helps
May 22, 2010 | Microsoft Windows XP Professional SP2
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
My server can't boot
Hi ,
You have not mentioned which Operating System . If its for 2003 follow the steps.
To install the Recovery Console as a startup option:
  1. While Windows is running, insert the Windows Server 2003 CD in the computer's CD or DVD drive.
  2. Click Start, and then click Run.
  3. In the Open box, type the following line, where drive is the drive letter of the computer's CD drive or DVD drive that contains the Windows Server 2003 CD, and then click OK: drive:\i386\winnt32.exe /cmdcons
    To install Recovery console as a startup option for Windows Server 2003 x64 edition, type the following line: drive:\amd64\winnt32.exe /cmdcons
  4. Click Yes when the message appears, to install the Recovery Console.
  5. When you receive the message that states that the Recovery Console is successfully installed, click OK.
  6. To use the Recovery Console, restart the computer, and then use the ARROW keys to select Microsoft Windows Recovery Console in the Please select the operating system to start list.
uparrow.gifBack to the top How to Remove the Recovery Console loadTOCNode(2, 'summary'); As a precaution, do not remove the Recovery Console. However, if you want to remove the Recovery Console, you must do so manually.
To remove the Recovery Console, follow these steps:
  1. Restart the computer.
  2. Click Start, and then click My Computer.
  3. Turn on the Show hidden files and folders option (if it is not already turned on). To do so, follow these steps:
    1. On the Tools menu, click Folder Options.
    2. Click the View tab.
    3. Click Show hidden files and folders, click to clear the Hide protected operating system files (Recommended) check box (if it is selected), and then click OK.
  4. Double-click the drive letter that represents the hard disk on which you installed the Recovery Console.
  5. Delete the Cmdcons folder from the root folder, and then delete the Cmldr file. To do so, follow these steps:
    1. Right-click Cmdcons, and then click Delete. Follow the instructions that appear on the screen, and then click Yes to confirm the deletion.
    2. Right-click Cmldr, and then click Delete. Follow the instructions that appear on the screen, and then click Yes to confirm the deletion.
  6. Remove the Recovery Console entry from the Boot.ini file. To do so, follow these steps.
    WARNING: Incorrectly modifying the Boot.ini file may prevent your computer from restarting. Make sure that you delete only the entry for the Recovery Console.
    1. At the root folder, right-click the Boot.ini file, and then click Properties. Click to clear the Read-only check box, and then click OK.
    2. Open the Boot.ini file in Notepad.
    3. Locate the Recovery Console entry, and then delete it. The Recovery Console entry looks similar to the following line: C:\cmdcons\bootsect.dat="Microsoft Windows Recovery Console" /cmdcons
    4. On the File menu, click Save, and then click Exit to quit Notepad.
  7. Change the attribute for the Boot.ini file back to Read-only. To do so, right-click Boot.ini, and then click Properties. Click to select the Read-only check box, and then click OK.
Oct 12, 2009 | Acer Altos G710 Server
Dec 28, 2008 | Microsoft Windows XP Professional for PC
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
timeout=30
[operating systems]
In my pc there is an problem of NTLDR missing . why this ill occure?
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears: [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
    If you receive the following message, the Boot.ini file may be missing or damaged:The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file:[boot loader]
      timeout=30
      [operating systems]
      For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Dec 05, 2008 | Computers & Internet
Operating sytem problem
format ur drive where u install win server 2008...tats it..
Sep 22, 2008 | Microsoft Windows XP Professional
Booting error
What I would do is take the hard drive (1) out of that machine and put into an another pc - xp would be fine. Now go to the root of harddrive (1) and edit the boot.ini file. you will see an entry similar to this ......
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
All you need to do is make sure you know which disk you're using (c drive is 0 usually) and the partition should be set to 1 for regular installations.
Did you add any drives lately? or make any changes to your OS?
Jun 14, 2008 | Microsoft Windows Server Standard 2003 for...
Error on windows load
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
Winxp cannot boot - missing files message
Just make sure you get these files on your computer.
Download hal.dll from here:
http://www.dll-files.com/dllindex/dll-files.shtml?hal
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
978 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
