Question about Sony Televison & Video
Code for Sony DVD Recorder Remote to control Mitsubishi TV
Hi, I have just purchased a Sony RDR-HXD890 DVD Recorder. The remote it comes with can be programmed to control the TV.
However the list of codes in the manual does NOT list MITSUBISHI, can you supply the code? or maybe its time for a new TV.?
SOURCE: new problem with tv and Sony RMT-V202 Remote Control
Samsung makes AVOL you may want to try there codes. Hope this helps.
Posted on Feb 17, 2008
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
  • 6 Answers
SOURCE: dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Posted on Mar 31, 2008
Basti
  • 1447 Answers
SOURCE: TV code number
070 147 126
085 139 041
079
try these codes closest i can get
Posted on May 13, 2008
  • 133 Answers
SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
Remote RMT-D240A not working with RDR-VX525 DVD Player that it came with. Only get DVD Screen saying DVD 3, will not even turn ON/OFF.
You may have to reset the remote to the current command code. Here is the link for how to do that. http://community.sony.com/t5/Remote-Controls/RDR-VX525-Changed-to-DVD3-on-command-control-and-remote-won-t/td-p/158777
Dec 17, 2010 | Sony RDR-VX525 DVD Recorder/VCR
TV code number
0056 is the code for the LG TV.
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
IrishDruid
May 13, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony Remote - Acer LCD TV
hmmm..well..that would be on the acer website, methinks..
check this link and find the acer icon..you may find it in there, under the LCD information(by model)
Mar 25, 2008 | Televison & Video
The dvd mode was changed do 2 how can i change it back to mode3 the remote does no work
I have a dvd SONY RDR-GX220 Recorder from the year 2006 and i want to connect this DVD to Videorecorder and decoder for TV, beucause I want to see TV connect with decoder; Videorecorder and recorder and play DVD. After change (from SYSTEM MENU and submenu Other from DVD3 in DVD1, I mistake beucause i know to not must change), remote control NOT ANSWER at the DVD. I can possibility General RESET manually this DVD and i can this function the remote control before changed?or in the remomote control?
Oct 28, 2010 | Sony RDR-GX220 DVD Recorder
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Jun 22, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Remote control for Sony DVD recorder RDR GX3
I just replied your question about remote.
Please click HERE to see.
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Cannot remove caption
Press the info button once on the HXD890's remote control (button top right on the main circle in the middle). All should then dissappear.
Nov 25, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Command mode
I did the same thing and lost all remote control to the recorder. Try holding ENTER & 3 in unison for as long as it takes (30 secs or more ) to view change on TV screen. This should get u back to system menu where u can change back to dvd 3 (default ) If doesn't work get a one for all remote and enter code 0533 which will get u in to the recorder command lines. PS enter & 3 worked 4 me.
Oct 22, 2008 | Sony RDR-GX300 DVD Recorder
Televison & Video Logo
157 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
