Question about Olympus Stylus 710 Digital Camera
Memory card wont lock in
I try to put my memory card in it's slot but it wont go down all the way and lock in. when i close the lid to where the battery and memory card goes, it goes into place and the camera registers that it is in, however i do not think that this is how it is supposed to be since ive had this camera before; the memory card was able to lock/click into place. any help/advice would be appreciated. Thanks! Sally
  • 32 Answers
Its because the spring whick locks the memory card has some fault thus it will lock only if given a force which keeps it in place thus the battery cover is providing that force and this can be left as such no problem will be there and can be rectified by visiting an auth. technician and repairing it
Posted on Apr 25, 2007
My memory card won't go down and lock into place. I've tried several different cards. None of them will lock into place
Be carefull, never use force. Check if you don't try to put in the card the wrong way around. Then check if nothing is damaged inside the memory slot. You need a bright light and perhaps a magnifying glass, because everything is very small. Compare the memory slot with a memory slot from another camera. Watch how the little knobs on the side look. I don't mean the contacts. When the contacts are bent, there is a possibility someone once pressed a memory card in the wrong way around and damaged the contacts and knob to secure the card.
May 25, 2014 | Canon PowerShot SX130 IS Digital Camera
How do you put a memory card into the memory card bit?
if it is an external slot ..and not under the back lid...just remove the cover ..and insert the card and pres it in ...it has a click action that locks it in ...and the same when you will want to remove it ...press it with the nail ..inside and after the click will pop out ....If the slot is internal ..see that is has a metal cover that locks in one end and if you pull it out it opens like a lid...insert the card and cover it back ..
Mar 16, 2011 | LG GT540 Cell Phone
Where do I put the memory card
where do you put your memory card?
i guess its a piece of cake.
at the left side of the phone under the infrared slot there is the slot for memory card. just open its lid insert the memory card in the right direction and your memory card will be read by your phone.
Feb 10, 2010 | Nokia N95 Cellular Phone
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Memory card is locked please help
Did you using SD card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
Jul 07, 2009 | Konica Minolta DiMAGE Z1 Digital Camera
Memory Card Slot Not letting it insert fully, seat, lock in place
It may be that you are trying to put it in backwards. It can go in only one way, contacts first. The last bit in "is" spring loaded so it will take a "little" force. If it truly will no go down pull it out, spin it 180 degrees and try installing it again.
Apr 28, 2009 | Kodak EasyShare DX4530 Digital Camera
When I put a memory card in slot A it wont work
take the gc apart and look at the memory card slot number 1 it may have ben bent sumhow idk if u have younger bros or sis's they may have tried to put 1 in upside down or summin
Mar 24, 2009 | Nintendo GameCube Console
My vivitarN1659 will not reconize a1gb memory card and either states that the memory is full or that the memory is locked
There should be a tiny lever on the side of the memory card. Unlock the card by pushing the lever up. If it still says memory card is full, take out the battery and push the memory card further into the slot. It should not move while it is in the slot. If it "floats" when you close the battery door, it is not down far enough into the slot. Return the battery and close the door.
Oct 05, 2008 | Cameras
Card cover open display wont come off the lid is a lil open how can i fix its for an olympus digital camera 6.0 mp
Check you memory card slot cover.. it shuldnt b closed properly...
Close it properly and try it!
Sep 22, 2008 | Cameras
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Apr 24, 2008 | Cameras
Olympus Stylus 710 Digital Camera Logo
130 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
