Question about Soundstream Car Audio & Video
Soundstream amp blows fuses
I have a USA 180 and USA 204 and when u turn them on the main fuse inside the amo blows imediately.
  • 4 Answers
Try to disconect the speakers and turn the amp on and tell if it still blows the fuse
Posted on Dec 28, 2008
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
This is milt with the ignition fuse problem. the truck is a 1989 chevy k2500 4wd
good morning milt,so your saying its the ignition fuse that keeps blowing in the fuse block inside truck,is that right,and does it blow imediately or take sometime.
Jan 10, 2015 | Cars & Trucks
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
Replaced alternator and accidently grounded battery cables and know it wont even crank over
you skipped the 1st step
disconnect battery minus lug 1st, , rule 1st off. last on, all cars. USA.
so you blew up the fuse, or fuseable link there next or inside
the main box. PDC the main power box has huge fuses.
this is covered in the FSM. buy one, so you know the steps.
and not get hit with flying acid. (photos not pretty)
or
alldata.com RTM
if you had a voltmeter, all this would be seen now
you see voltage at battery but it dont make it past the PDC
simple cause. fuse blow.
12v xxxxxxxxfusexxxxxxxxxxx-0v
see my schematic. see 0v, bingo, fuse blown.
every time.
Apr 01, 2014 | 2007 Suzuki XL-7
1998 dodge ram 1500 dash lights wont work
Walker Muffler - Aluminized Steel Direct OE Replacement 1998-2001 Dodge Ram 1500.-------------------------------------------------------------------------------------
SLIM HID XENON light
Jan 10, 2013 | 1998 Dodge Ram 1500 4WD
Everytime i plug in my speakers and turn the power on the fuse imediately blows...ive changed the fuse and the two fuses on the inside of the sud dont look blown what should i do...these are the best...
Yes I have had these for many years. Work great. However there is a resistor that has been known to fry. Due to the connector plug (which is a flaky round pin connection.) arcing and once that happens it. You get current overloads, hence fuse blows.
Unfortunately parts are scarce and not label easily to get replacements. So I just bought new
GL
hope this helps
don
Jul 11, 2011 | Klipsch ProMedia 21 2 Speakers
I am trying to distinguish whether a fuse panel in a home is 60 amo or 100 amp. It is not labeled on the main breaker?
Hi RC,
Yes, it should be the main breaker controlling all the rest collectively. It should also be written on the door of the panel by the electician that diod the install.
Best regards
Mike
Dec 19, 2009 | Federal Industries 15 Amp Federal Pacific...
Compaq presario m2000 imediately shuts down after
Check for blocked air passages - vacuum out the fan ports. (Don't use canned air - you'll just blow the dust inside, where it will act as an insulator and help things overheat.) Make sure the fans are actually turning. If there's any mold growing inside, that could cause the problem too.And for more contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | Compaq Presario M2000 Notebook
Emerson Microwave (mw8992rd) not heating up
I have replaced the main fuse on this model. Though blown main fuses are common in this model, it will not even turn on when they blow, so your problem is most likely NOT a blown fuse. I had heard of your problem so, when replacing the main fuse inside one, I looked for additional fuses and saw none. The store was wrong. Even if it were a fuse, the security Torx screws mean that you couldn't replace the fuse anyway.
This microwave seems to have been haphazarly been recommended by Consumer Reports, but it is terribly unreliable. The turntables break when popping popcorn, the main fuse repeatedly blows, and they also stop heating.
Oct 19, 2008 | Emerson MW8985W Microwave Oven
Car Audio & Video Logo
238 people viewed this question
Top Soundstream Car Audio & Video Experts
Jerry Umali
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
