Question about HP Pavilion dv4000 Notebook
Touchpad Not Working
Hi. I have an HP Pavilion Dv4 1147cl Entertainment PC. Lately, I have been using the touchpad mouse, which has been working fine. I recently got a wireless USB mouse, which I started to use. Today, I realized that my touchpad mouse will not work, at all. I've tried uninstalling drivers, FN + F9 key, BIOS updates, all of what could seem to be the possible problem. I'm sure that all the settings are correct, and all the drivers are how they should be. Why isn't my touchpad working?
  • Jamie Inscore
    Jamie Inscore May 11, 2010
    Does your notebook have an enable/disable button for the touchpad?
  • 56 Answers
Those laptops have a button just over the touchpad if the light in it is orange/redish its of if its blue its turned on if the touch pad doesent work while its a blue ligt it may be some thing wrong with it.
Posted on Jan 02, 2009
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Describe your HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook Problem my internal mouse is locked, I dont know why and dont know how to fix it (I dont use an external mouse or keyboard). ...
Hi melissamhahn..
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | HP Pavilion dv9000z Notebook
I have an HP G60 and my mouse touchpad is locked, like the mouse on the screen wont move at all.
There is a led light for the touchpad just above the touchpad. If it is amber in colour tap the button ju8st next to the light. you will see that the light will change in blue. if it has changed then it has unlocked and the touchpad will work fine.
Feb 03, 2010 | HP Pavilion dv6000z Notebook
Mouse pad stopped working on actual laptop but will work when using wireless mouse.
Try uninstalling the touchpad driver from the Device Manager, restart the Computer and reinstall the Touuchpad driver after connecting a wireless mouse.
If the issue persists then this indicates that the issue is with the Touchpad sensor and requires to get the Touchpad serviced.
Dec 01, 2009 | HP Pavilion dv6000z Notebook
My toshiba touchpad is not working
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is enabled. If it is not, then change the setting to enabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
Nov 02, 2009 | HP Pavilion dv4000 Notebook
Touchpad scrollbar feature is disabled on my laptop
Hi there.
The keyboard toggle to reactivate the touchpad is Fn - F7
Please post back if the problem persists.
Good luck and thanks for using FixYa!!
May 24, 2009 | HP Pavilion DV9740US Laptop
HP Pavilion Entertainment PC - scrollbar on mouse pad not working
I think I can help you. I need to know what kind of mouse driver you are using. To find out click on the control panel, click on mouse properties, click on device settings. Under devices it should show Enabled/Name/Port. Under Enabled it should say Yes. Under Name should give the name of the device being used and under Port it may or may not show anything. Ex. Yes /Synaptic TouchPad V7.2 / Port/2. If this is what yours shows, double click on the highlighted device and a menu will come up. From there you can reactivate your scrollbar. If yours does not show a device in the list, sometimes it will show where to go to download the device in the bottom righthand corner. EX:( If not, you will have to find the name of your device. Hope this helps. Tim
Jan 10, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion dv9843 notebook
Most likely you have to double tap. Depending on the laptop make, sometimes double tapping isn't intergrated.
Jun 29, 2008 | HP Pavilion dv4000 Notebook
L100 touchpad
check in the BIOS settings, If you have a mouse plugged in, it may disable the touchpad.
NOT SURE? see a Tech.
Feb 18, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv4000 Notebook Logo
1,832 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
