Question about KitchenAid KESC307 Electric Kitchen Range
Oven vents on front are stained and ugly. How do I clean them?
I gave my Mom a Maytag Self-cleaning Oven in 2001 as a Christmas Gift. This now 7 year old oven has in time formed ugly brown stains just above the small front oven vents openings and these stains look really bad. The rest of the oven and stove top look great. However these stains make it appear dirty even though the stained areas are each only about 2 inches across. I have tried Goof Off and brushes but they do no good. I do not want to scratch the paint but so far have had no luck getting these stains removed. I would really like to clean this oven for her and get rid of these stains. Does anyone know how to remove these stains?
  • 1 more comment
  • David Kado Dec 29, 2008
    Thanks for your assistance. My only question now is would it be better to use Bisque colored touch-up paint to cover it? Or would that just make it look worse? The areas are about 2" across and there are 2 of them each one is only about 1/4 of an inch high. So they are both small areas but really look bad.
  • David Kado Dec 30, 2008
    Thanks for letting me know. I am going to have to think about it. There really is no long term fix as either way the ugly stain mark will reappear. One thing I am sure about. If I ever buy another range I will be paying close attention to location of the vents. You would think that in 2008 almost 2009 there must be companies that have recognized this problem. Seems like the vents could be located where there would be no paint that would stain. Thanks for your help.
  • Anonymous Jan 02, 2009
    I took off and disassembled the door the Maytag Oven Door on New Years Day. It turns out that the oven vents are located on a PLASTIC part that would not be paintable. O decided to replace the part #778537 that was about $30 from repairclinic.com
    Also decided to replace the oven door trim insert (also very stained) since it was only $8 (part # 778514) . I decided painting plastic parts was not a good idea. Also this Maytag Oven, Model Number MER5770AAA, oddly seems to be called Almond at times and also Bisque color. So was not sure what color paint I would need. Does anyone know if Almond and Bisque are in fact that same color when it comes to Appliances such as Oven/Ranges??
  • 318 Answers
Sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Posted on Dec 28, 2008
  • Tom Zwiebel
    Tom Zwiebel Dec 30, 2008
    the touch up paint is made for chips out of a thick area and wont look very good for your flat area. if you can go to an appliance parts store, they will have a spray can type paint that would look betterbut will also discolor after a few uses of the oven. either way i would recommend the spray paint over a touch up bottle.
    if you dont havd a parts house close, then go to a hardware store and try to get the closest color you can in a spray paint enamel.
    New Friend:
My Kitchen Aid Convection oven did the same thing. Where the vents are located at the top of the oven door all turned yellow. The Magic Eraser does not work. I tried several other cleaners and had no luck. This stove cost 2800.00 and the knobs were a problem too. After two months the marks for the temperature settings all came off. They were grey painted markings on white knobs. Very disappointed!! Thought Kitchen Aid was reputable!
Posted on Mar 27, 2013
There is always a yellowish staining on the top part of the oven door, door handle and vents after self cleaning. I've tried bleach, sos, Mr. Clean Magic pads and it barely removes it. What do you...
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Mar 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Hi, I have a wonderful Maytag speckled black smooth top stove. Over Christmas someone caused a big (2 " diameter) stain. I've tried everything to get it out. is it possible to have a new ceramic...
Ceramic cooktop cleaning tips - especially for 2-in difficult-to-remove stain:
Best Idea: "Cerama Bryte" + plastic scrubbie
Cerama Bryte is specifically designed for this cooktop, works on stains, avail at Hardware Stores.
Other ceramic cooktop tips:
1. "Soft Scrub" plasic scrubbie
2. Comet cleanser + sponge
3. Single-edge razor blade held at 45-degree angle - scrapes off material
4. "Cook Top" cleaner (WalMart) + Mr. Clean "Magic Eraser" abrasive pad
5. baking soda on damp sponge
6. soak stain for awhile with Formula 409, Fantastic, or citrus degreaser ("Orange Clean")
7. ammonia + water - in a 1:1 solution
8. Easy Off oven cleaner - it foams on the stain and does the work for you - let it sit 20 min.
9. the nuclear option:
Cerama Bryte under a plastic scrubbie under an orbital sander with sandpaper removed
(just the pad down on top of the scrubbie), after pre-soaking in Citrus Degreaser.
The sander is a power tool which only saves your joints, and speeds up the chore.
Jan 17, 2011 | Maytag MER5775Q Electric Kitchen Range
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Ihave a ge ceramic top stove,everytime I self clean the oven it stains in the front of the oven get worse.I have tried everything.My stove is bisque and the stains are an ugly yellow.
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Jan 06, 2010 | KitchenAid KESC307 Electric Kitchen Range
Aft self-cleaning, top of oven door and knob panel discolored
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Oct 24, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
WHITE FILM INSIDE OVEN
your mom may have used a non-self cleaning cleaner to try and clean this oven in the past. you wont have much luck getting rid of the stain but using cleaners like easy-off or mr muscle may help you reduce the staining.
it could also be that an element has shorted out and "burned" the surface of the oven. if the oven doesnt heat properly then check the elements for a rough or burnt out area. that does happen but its probably just going to be stained as it sounds like you have tried to do the cleaning.
p.s. i like mr muscle better then easy-off.
Jan 09, 2009 | Tappan TGF320 Gas Kitchen Range
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Inside the oven door there are some stains from liquid spill that went through the vent, how can I clean it.
If your oven is self-cleaning, consult the owner's manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner's manual or contact the manufacturer of your oven for further information.
To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
May 04, 2008 | Kitchen Ranges
KitchenAid KESC307 Electric Kitchen Range Logo
2,587 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
