Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output.
S. Mohan
The best way to check if the scanner is okay or not is by installing on another computer. First try B&W, then try color. IF it works may be your OS or driver (of the old comp) is corrupted.
S. Mohan
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan.
If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical).
The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark.
Hope this helps :)
i hav the same prob. help me
