Laptop monitor malfunction with dotted lines covering the display
My latop dv 2713 is defective from the day - 19 may 2008.It has ugly dotted lines on it's screen . pl help.
  • Anonymous Jan 01, 2009
    my lap top also weird dotted lines on the screen on 4 different places. anyone can help?
My Settings/Advanced/Displays, don't show, there is no setting to use any ex. screens I have 2-Inspiron 8500s my other one shows the setting display but one don't can you tell me what to do to get...
LAPTOP OR NOTEBOOK COMPUTERS HAVE A KEY ON THE KEYBOARD IN THE LOWER LEFT SIDE THAT HAS A "Fn" MARKED ON IT, SHOULD BE BY THE CTRL KEY. PRESS THIS KEY ALONG WITH AN "F"KEY, NORMALY F5, ( HAS 2-BOXES WITH A DIVIDER LINE), WILL CAUSE YOUR SCREEN TO GO BLANK AS IT IS NOW SENDING THE VIDEO TO AN EXTERNAL MONITOR. PRESSING THE 2-KEYS AGAIN WILL APPLYTHE VIDEO TO BOTH MONITORS, THEN PRESSING BOTH AGAIN WILL RETURN IT TO YOUR LATOP ONLY.
Aug 24, 2011 | Dell Inspiron 8500 Notebook
HI, shows blinking green line of about 2mm at the bottom of the screen of my VAIO. Could you advise to resolve the issue
Most of the times this is a screen issue. Meaning that you will have to change your screen eventually.
To be sure, connect the laptop to an external monitor and look at the display of that screen.
If you see the same green line, then the motherboard could be defect.
If you do not see the green line, then there is something wrong with your laptop screen.
If the screen is malfunctioning, the first thing you should do, is open the laptop, and check the wiring of the screen. If this does not solve the error, you should replace the screen.
Mar 07, 2011 | Sony Computers & Internet
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Jan 19, 2011 | Toshiba Satellite L675-S7048 Notebook
I have a Toshiba Latop (P105 S6217) (SN=17122387W) (Mod=PSPADU 00W00S). In recent days, I am getting very thin lines across my display screen. Could this possibly been the Mother Board going bad. The...
You possibly have a LCD screen failing, but to be 100% sure, you should hook your laptop to an external monitor, and see if the display is good . Any desktop monitor will work. If your display is good, you know your LCD on your laptop is failing, and if it is the same display as your laptop, you know you have a video chip problem on your laptop motherboard.
Sep 21, 2010 | Toshiba Computers & Internet
Periodically the screen is captured by horizontal lines completely across the screen. Cannot access programs or even shut down properly. Any suggestions. Presario 700 laptop using Windows Vista. Thanks
This issue is due to the malfunctioning of the screen or due to any other internal hardware malfunctioning of the notebook.
To further isolate the issue, I request you to connect the external monitor and check.
Once after connecting the external monitor, please tsp Fn+F3 Switch between the display and external monitor in the following order:
Display
External monitor
Display and external monitor
If the external display is fine then the issue either could be due the malfunctioning of the display cable connector between the screen of the notebook and motherboard or due to the malfunctioning of the screen.
As this the hardware issue, Please contact the nearest repair center to get it resolved.
May 29, 2010 | Compaq Presario 700 470024-192 Notebook
I have sahara laptop model no al 096 i want to install vga for dual monitor
i have sahara laptop model no al-096. i want to install vga driver.which driver prefeered to install in this latop.
Nov 08, 2009 | Dell Dimension 8300 PC Desktop
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Dec 26, 2008 | HP Pavilion dv7-1130us laptop
Laptop malfunctioning
Connect any Desktop monitor to the Laptop and check whether the Display. if the display is fine on the Desktop monitor screen then it can be identified as the Laptop screen malfunctioning.
And if the Display has the same issue that on the Laptop screen
then it can be treated as the Display card issue.
However, it seems to be Harwre related issue. Get the laptop veriufied under Technical supervision to repair the Laptop's display card or the Laptop screen to be replaced if the display is fine on the Externally connectd Monitor.
Aug 04, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
149 people viewed this question
Alun Cox
David Payne
David Payne
