Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Without flash Just bought the Nikon D40, wonderful camera!! I came across a problem today, took pictures of niece while in Annie play, which pictures must be taken w/o flash, eventhough I was on sitting in 2nd role, some pictures came out distorted, blurry, worse when she was jumping and dancing. How do I fix this problem?? HELP
  • msampayo Dec 29, 2008
    Thank you
    Novelist:
  • 121 Answers
Although your eyes can adapt to see well in low light, the camera needs a lot more light to take good photos than your eye needs to see in low light. Taking photos of a play or other indoor performance is a very difficult situation.
1) You need a fast lens, one that shoots at aperture f/2.8 or faster (i.e. f/2.0, f/1.8, or f/1.4). Your 18-55 lens is f/3.5-5.6, which is not a fast lens. When you zoom to 55mm, you can only shoot at f/5.6 which is 1/4 the light gathered at f/2.8, so the shutter speed needs to be 4 times longer, which means 4 times slower.
2) Set the camera to use the highest ISO it offers. Look in your manual for instructions on how to change the ISO. Don't forget to set it back when you are done!
3) Use the shooting mode that lets you specify the aperture. The camera will select the shutter. I'm not familar with the mode name for Nikon cameras - for a Canon camera this is the AV mode (for Aperture Value).
4) You may want to dial in some -EV - this means a "minus" value in the Exposure Compensation. I usually set this to -1/2 or -1 for low light shots. The photos come out just a tiny bit darker than normal, but the trade-off is that I get a faster shutter speed.
5) Even with all the settings above, the shutter speed is likely to still be quite slow. You must hold the camera very still. A monopod or tripod is usually necessary. In addition it helps if your lens has VR (vibration reduction) to minimize camera shake. Finally, no matter how still you hold the camera, if the subject is moving then the image will be blurry. So only shoot when the subject (person on stage) is relatively still.
If you don't have your camera manual let me know, and I'll look for it online and give you a link to the pages that detail the settings you need to change.
Posted on Dec 28, 2008
My Nikon D40 won't take pictures!
Your twin sister #&%@ed up your camera.
Jun 07, 2010 | Nikon D40x Digital Camera
Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Just bought a Nikon D40 Camera and sometimes when I view pictures that have been taken, the pictures get distorted. Is this common or and easy fix. dee
Your pictures are most probably distorted because of camera shake.
If you invest in a Nikon lens with VR = vibration reduction or a Sigma hsm os = optical stabilization, this will allow you to shoot at slower speeds and will reduce camera shake.
The most obvious problem will be shooting in low light conditions without vr or os...this will give blurred images.You will need to up the iso and shutter speed with a wide aperture to achieve more stable images.
Bear in mind, when you raise the iso, you will get noiser images and the Nikon D40 does not handle noise very well - but can be eliminated with software.
Hope this helps.
Oct 03, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Is a Quantaray QF30 compatible for a Nikon D40 camera?
I bought this flash on craigs list today for about 30 dollars. I did research and as long as the flash you buy is a nikon HOT SHOE mount it will work. (Look on the bottom of the flash) it will say Nikon i-ttl. I am using it on my D40.
May 12, 2009 | Quantaray QF30 for Nikon Flash
Picture transfer from internal memory
Your D40 has no internal memory. The camera can take a shot, and even show you the image on the LCD, but is not actually saved anywhere, unless a memory card is present. There is a way to prevent the camera from firing without a card. It is in the setup menus.
May 05, 2009 | Nikon D40x Digital Camera
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Nikon D40 shutter speed problem
The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. http://www.facebook.com/home.php?src=fftb#/pages/Keller-TX/Raving-Design/78762448229?v=photos&ref=ts Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
Dec 20, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
D40x flash not working
I have also had the problem of flash not working on my Nikon D40. I found out the problem and I also made a quick video to help those who are having this problem. Here's the link to the video: Hope this helps !
Nikon D40 Flash Fix
Nov 03, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
