Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Steady flashing amber light
After replacing buld and turned TV on, power light goes green for about 2 secs and then goes to a steady flashing amber light. In this instance it flashes 6 times between 2 sec intervals. Any ideas what can be the problem, any help would be greatly appreciated!
    Problem Solver:
  • 12 Answers
The set contains two air filters within they are gonna be clogged up not allowing air to move smooth or a bad fan or one going bad the set has four fans two 80mm fans to check a 120mm fan and a blower fan below the lens. If it flashes then goes to red then you hit power and it starts up. Then it's a fan or a air filter issue must check line voltage. For each fan
Posted on Feb 28, 2015
  • 47 Answers
It could be the ballast.
Posted on Jan 05, 2009
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
Dec 28, 2010 | Dell Axim X51v Pocket PC
Tv was working fine. turned it on, the green power light flashes. power it down and the power light is steady red and the lamp light flashed red
you need to replace the lamp This unit has 2 different LAMPS used, one is SQUARE and the other is ROUND.
Dec 18, 2010 | Zenith Z52SZ80 TV
Orange battery light is doing a double blink right now... Does that mean the battery is being charged??
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
or you may try If an AC adapter is not connected to your computer, the computer's power source
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Yes. Your original battery is defective - please look for a replacement. Hope it helps.
Jun 25, 2010 | Sony VAIO PCG-K35 Notebook
Dell Dimension 2400 with steady amber power light and diagnostic lights of ABC green and D off. What could be the problem?
Steady amber power LED is indicative of a problem with the motherboard. Remove all external connections except power, remove all PCI Cards, ram, disconnect power from all drives, turn on see if power LED is still steady amber. If it is, more than likely the motherboard has a failure. Also check to see if the CPU heatsink is firmly seated (The plastic retainer has been known to fail causing the CPU to overheat)
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
Hi - My 2wire 1701 gateway has steady green power light and steady local network light but the broadband link light is steady amber. My computer is receiving the WiFi signal but I cannot get any internet...
The broadband link light tells you the status of the connection between the modem and the broadband servers in your area. Green means everything is A-Ok while amber means your modem is not picking up a broadband signal.
Try turning the modem off and on and also make sure the cables are secure while you're at it. If the broadband light is still amber, the only thing you could do next is to call your internet service provider.
Oct 01, 2009 | 2wire Computers & Internet
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Panny pt-50lc13 steady amber flashing light
Sounds like a defective lamp diever or ballast.Listen for a buzzing sound when you turn the set on. If you do not hear it then most likely you have a bad ballast or lamp driver. Worst case scenerio would be the engine itself.
Dec 28, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
235 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
