Question about Magellan eXplorist 600 GPS Receiver
Cannot communicate with pc/ laptop. device is not recognised
When i connect my magellan explorist 600 to my pc/ laptop, it is not recognised. i get a message " usb device not recognised - one of your usb device seems to be malfunctioning etc...." i have installed the software provide in the cd.
  • 5 more comments
  • bsegal Nov 13, 2007
    Hi, Yes I have the same problem with the Explorist 500. Got any reply on that ?
  • finiusj Jan 18, 2008
    I am having the same problem. Has anyone come up with a solution? I am running Windows XP.
  • jrbuc Apr 03, 2008
    plugged my 600 explorist unit in the pc device is not recognized.
    pc says that driver update is the best one suited, but this does not solve the problem. According to the pc, it is still showing unknown device at the usb driver scree. the explorist screen shows that it is communicating with the host machine. Is the usb cable bad?
  • BRUNO63 May 13, 2008
    Same problem for me too.
  • Anonymous Jun 03, 2008
    same problem
  • Anonymous Jun 24, 2008
    Amazing what connecting the serial port properly will do...
    try turning the screw in connection the other way and you should be much happier with the results.
  • Anonymous Mar 25, 2014
    my explorist gc does not downlad caches it says magellan communicator not found
You probably have the USB adapter connected upside-down on the unit.
Posted on Jan 19, 2008
Me too
Posted on Jun 03, 2008
Me too! It's annoying
Posted on Mar 07, 2008
Me too! Can anyone save me from this nightmare???
Posted on Dec 18, 2007
I had the same problem and sure enough the cord with the screw in it was upside down.
Amazing what connecting the unit properly will do...
Posted on Jun 24, 2008
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
I want to buy a replacement battery for my Magellan eXplorist 600. How difficult is it change it? How do I do it?
Try this address http://www.magellangps.com/assets/manuals/eXplorist_600_en.pdf I checked the manual looks like it is real easy, just not sure where you get the battery from. Hope this helps
Apr 01, 2010 | Magellan Replacement MAGELLAN EXPLORIST...
Hello, I have an Explorist 600 that got wet and no longer turns on. Can you fix this and if so at what cost?
  • Try to call the tech support of magellan and advise them that your unit is no longer working. If you still have the receipt and still under warranty then they will fix it for free or if its not they can fix it for free for one time courtesy. And they are also offering a trade in for cheap price.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Feb 12, 2010 | Magellan eXplorist 600 GPS Receiver
NMEA communication does not work ( but file transfer is OK)
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Jun 06, 2008 | Magellan eXplorist 500 GPS Receiver
Replacement keypad membrane
If you look on magellan website it states they no longer have or support replacement parts for older gps models.
You can find an explorist for parts on ebay.
I own a explorist 100, 400, 500. I believe the key pads are all the same. If you can not find one, I will sell you the pad from the explorist 100 for 30 dollars plus shipping.
May 08, 2008 | Magellan eXplorist 600 GPS Receiver
LCD screen magellan explorist 210
you are welcome , but send me detailed photo of that lcd
Apr 29, 2008 | Magellan eXplorist 210 GPS Receiver
Magellan explorist 600 gps with windows xp
It is more than likely a defective USB cable. I am on my third cable. They don't stand up to the abuse.
Apr 03, 2008 | Magellan eXplorist 600 GPS Receiver
Fault mesage on screen when first strat magellan 500
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
Sep 04, 2007 | Magellan eXplorist 500 GPS Receiver
No communication with computer
I would try downloading the USB driver from magellan (if they offer it).  You may also be able to get the driver from C-Map USA as the do the map software for magellan.
Sep 04, 2007 | Magellan eXplorist 400 GPS Receiver
Magellan eXplorist 600 GPS Receiver Logo
620 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
