Question about Celestron NexStar 8 Tripod
Problem rotating Celectron Nexstar 8
The telescope only has about 100 degrees of rotation, horizontally. I am a teacher and found this beauty locked in a storage cupboard. Then I took it home and set it up, and now I realise why someone may have wanted it hidden. Any suggestions? Or an online service manual? The regular manual isn't any help.
    Top Expert:
  • Celestron Master
  • 50,354 Answers
Search google , just like we would have to . Google
Posted on Jan 04, 2018
  • 44 Answers
SOURCE: celestron telescope
The hinge should be to the north. An imaginary line drawn perpendicular from the center of the tilt plate should point to Polaris (the North Star).
Posted on Jun 27, 2008
SOURCE: I have the Nexstar 8. It will not auto align or manual....
You must set TIME, DATE, and SITE-- probably does not know your actual location. Read the manual and perform all of the setup procedures.
Some of these have a "starting position" again read the manual and make sure you are in the "home" position before you start the alignment. Read my TIP on my profile page about GOTO telescopes, and join the NEXSTAR forum on www.cloudynights.com
Posted on Mar 27, 2010
First do a RESET on the hand controller and make sure TIME, DATE, and SITE, are correct.
If this does not work then RE-load the firmware in the hand controller. If that fails contact Celestron customer service.
http://www.celestron.com/c3/page.php?PageID=37
Posted on Jun 01, 2010
SOURCE: My NexStar 8 SE doesn't focus. When the focuser
The knob could have come loose from the mirror. This would require a return to Celestron for repair or a complete disassembly of the rear of the scope,
You can remove the focuser, and MAYBE it is just detached from the rod inside that moves the mirror back and forth.
Celestron support:
Posted on Aug 01, 2010
SOURCE: The Celestron Nexstar 4SE makes a weird cracking
Is the AZimuth clutch locked down? Then either a gear is broken inside or the worm gear inside has slipped and is not engaing. You can return these to Celestron for repair, here:
Posted on Dec 26, 2010
Testimonial: "I don't think there is an azimuth clutch... so I guess I will have to try to talk to Celestron. Thanks!"
The Celestron Nexstar 4SE makes a weird cracking noise when you press the left or right arrows on the controller. I tried taking it off of the tripod, and it still will not rotate left or right, even if...
Dec 26, 2010 | Celestron NexStar 4 SE Telescope
Sound like a gear inside is either broken or the worm gear is locked up. Celestron can repair this if you call them here:
My NexStar 8 SE doesn't focus. When the focuser knob is rotated either direction it moves the image up or down.
Celestron support:
Aug 01, 2010 | Celestron Optics
May 15, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
Mar 27, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
Everything is upside down
Astronomical telescopes produce an upside-down and reversed image (image is rotated 180 degrees from an upright position) since this doesn't matter when you are looking at things in the night sky. Accessories are available for rotating the image to an upright position, but most of those accessories do not work well with Newtonian style reflector telescopes such as the 114EQ reflector.
Jun 26, 2009 | Meade Infinity 114EQ-DH Telescope
Focus?
The C8 optical tube has a very large focal range. It should be capable of focusing on objects from 15' to infinity. To focus on object at infinity you have to move the primary mirror foward. You do this by rotating the focus knob CCW. Rotate the knob CCW until it comes toa stop them slowly bring the mirror back by rotating the knob CW while viewing the object. It will snap to focus so don't move too fast yor you'll miss it.
Jun 25, 2008 | Celestron NexStar 4 SE Telescope
Meade etx-80 sticking
Some (not all) versions have an end stop - it it just reaching that? The scope will rotate only aboit 3 complete turns between the 2 ends.
The 'correct' starting position is as follows: Place scope on tripod or table with control panel at the West. Unlock the declination lock (horizontal slew). Rotate scope anticlockwise until it hits the end stop, Then roate it back clockwise until scope is pointing North (should be about 3/8 of a turn, as the end stop is at South West). Then lock the declination, Set the tube horizontal and continue with the alignment process.
Autostar always thinks you have set the position like that. If you haven't, it will work OK until it tries to rotate past the point it won't go, then chaos results!
Feb 12, 2008 | Meade ETX-90 (48x90 mm)
Celestron Nexstar 11 GPS Electrical problem
The Nexstar11GPS group on Yahoo.com.
http://tech.groups.yahoo.com/group/NexStarGPS/files/n11gpselectronics.zip
Nov 06, 2007 | Celestron NexStar 11 Telescope
Celestron NexStar 8 Tripod Logo
56 people viewed this question
Top Celestron Photography Experts
pontelemon
pontelemon
Tony
Are you a Celestron Photography Expert? Answer questions, earn points and help others
