Question about LG LS-K1830CL Cool Mini Split Air Conditioner
In heat mode after a minute it stops and the power led blinks five times
  • 4 Answers
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Posted on Jan 20, 2009
Lg laptop not power on only blinking 16 times then stop green led indicator light on when i press the power bottom it will not turn on and green light indicator goes out.?
Did you try a hard stop? Hold the power button down for five to ten secs until all functioning stops, wait five secs then try to power it back up? I'm no laptop expert, but that has helped me a few times here and there.
Aug 24, 2016 | LG Computers & Internet
LG aircon flashes blinking 8 times and the shifts to timer led flashes blinking light 4 times
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.Air Bulance AC Cleaning Repair Services
Apr 23, 2014 | LG Heating & Cooling
Error code 67?
The indoor fan motor had blocked.
Feb 05, 2014 | LG LSN121HSV2 11,200 BTU 20 SEER Ductless...
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
Window air condition (LG)
Your coils could be dirty. Also try cleaning the air filter. I am not familar with your exact model but there will be a filter behind the plastic grill. Most of them pull out from the top or bottom of the case. As for the coils get a can of A/C coil cleaner from your local hardware store and follow the directions. Most of the time these two things will get your unit working again.
Jul 05, 2009 | LG Heat cool Window Air Conditioner
LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Feb 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating problem
The LG>LW5200ER AC is not listed as a heat providing unit. Click on link and this will give you the spec's
Hope this helps.
Oct 19, 2007 | LG LW5200ER Air Conditioner
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
878 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
