Question about iLO 3200 32 in. LCD Television
TV issue The problem with my TV is I can turn it on but nothing will work besides that the remote and the TV's power button work but nothing else. The channel changer and the volume won't respond on the manual buttons and the only button on the remote that works is the power button.
  • 2 more comments
  • habanaj Jan 02, 2008
    I dont see a phone number.
  • Big Lerm Jul 04, 2008
    all of a sudden my tv got stuck on Composite2 and will not change, the volume is extremely loud and will not allow me to turn it down at all! the only button that works on the remote is the power button, and all of the buttons on the side of the tv (excluding the master power button) do not work either....what is wrong with my tv??
  • Redbeard66 Jul 06, 2008
    same problem - remote is not working other than the on/off switch. The manula button attached to TV itslef do not even work.
  • Anonymous Mar 27, 2014
    remote didn't work some turn the tv on by the power button and it took about 15 min to come on
  • 3 Answers
Several on-line review sites discuss this problem. The main board in the TV is defective. Either return it to WalMart or contact the manufacturer.
Posted on Apr 30, 2007
First you should open the set and make sure that the cables are seated properly, could be a loose or pinched cable
My tv is an old rca tv, i have a dish network remote, one of the kids locked out the tv and i dont know how to get it back on, it wont tell me a anything all i can do is change the tv with the remote,...
If I read your post correctly it sounds like, the remote no longer works the volume or power for the TV set. If this is correct follow the steps below for a Power Scan. If this is not the issue or the steps don't work feel free to contact me and we will sort this out!
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Try several functions Mute Volume and Power to make sure the remote works properly then press "SAT".
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | RCA 32F531T 32" TV
My remote stopped working. I replaced batteries, nothing, bought a universal remote, followed directions nothing. Can the TV be the problem? Is there a factory reset on the TV?
it could be sensor on tv
try holding remote in front of a video recorder and if you push button on remote and view through video recorder you should be able to see the light blinking coming out of remote - if you see the light coming out of remote and it is still not working then the tvs sensor went bad
besides trying to unplug tv for a few minutes there is no reset for this issue
Mar 21, 2011 | Symphonic ST427FF TV
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
When turn on tv with remote and without remote it
I have the same tv. Something to remember is that the picture is lamp powered. It takes about 30 seconds to power on and takes about a minute to fully power off. I had issues when trying to turn on the TV, accidentally double tapping the button, which would turn it back off. I'd do the same when trying to turn off the tv.
If you are sure this isn't the issue and the lamp light is still on once the tv turns off, most likely your bulb is burnig out. You can find replacement bulbs on the internet. They are fairly easy to install yourself, so you shouldn't have to have the tv serviced.
If the bulb seems fine, your tv could possibly be overheating. In that case, make sure the vents are cleared as the tv gets pretty hot.
Jul 26, 2009 | Mitsubishi WD-60735 Projection Television
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
ESA 42' plasma turned off on it's own and won't turn back on.
I think, when a power supply's time is up, it's up now. There is not usually any advance warning,(besides your warranty has expired of course). If you are feeling un-normal heat from the TV, that is a sign the power board just fried out. They always get very hot, from the microchips cooking themselves until there is nothing left to need power. Plan on paying a TV tech to replace your power board.
Nov 13, 2008 | Televison & Video
How to set codes on my px-rc1 remote
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
May 18, 2008 | Universal Remote Control MX-500 LCD Remote...
iLO 3200 32 in. LCD Television Logo
62 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Saylor
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
