Screeching noise when rotating in either direction
SOURCE: help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
SOURCE: amana dryer loud noise
remove the lowe acesss panel( 2 5/16 screws) wiht the panel removed and a flashlight in hand, turn on the dryer and watch it tumble. you should be able to pinpoint where its coming from. its either the rear roller supports, the front drum glide assy's, or the tension pulley in ehich the belt its wrapped arund(develops a rut in which the belt has cut into it causing horrible screeeching noise, heck to replace all three of the components is problavle ony 50 bucks or so
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
