Question about Maxtor Hard Drive
Hdd c: problem
Sir,
i use maxtor 6vo80eo,i had often formatted my drive about 15 times with ntfs quick format ,now as i start my pc it takes about 20 min to load xp grapics and mouse arrow is it the bad sector problem what should i do?please sir explain
thanks
  • 13,433 Answers
Quick format only marks the disc as empty.
Try performing a CHKDSK /F /X /R C:
also do a full format next time, you may want to replace the hard drive, or you could try a program like HDD REGENERATOR or SPINRITE to fix it. These programs may not fix the hard drive as if it is too damaged but they may help in some problems.
Posted on Dec 28, 2008
I have a Maxtor 9NX2DT-500 hard drive for my PC can I copy my File on a Mac Air computer ( is it compatible ?)
Depends on what you want to do with the files. Data is usually interchangeable between Mac and PC file formats. FAT-32 format files are limited to 4gb in size. You cannot boot a Mac from one of these files or from a drive formatted to FAT-32. To be bootable, an Intel Mac system drive must be formatted as a GUID partition map. Most of the new hard drives come with software that enables Macs to read and write to them without reformatting, thus they are completely interchangeable for data.
Nov 25, 2014 | Maxtor Computers & Internet
Keeps freezing start up
Around 4 gb ?
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space.
The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor.
Make sure that the hard disk drive is at least 100 GB.
Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive.
Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E."
Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete.
Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard.
Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window.
Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software
http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html
http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html
When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces.
Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
Dec 12, 2013 | Iomega Computers & Internet
External hard drive cant format into ntfs but only exfat
The propriety NTFS file format is used by the Windows operating system to format internal as well as external hard drives. You can format an external hard drive with the NTFS format using the built-in program included with the Windows operating system. The procedure is straightforward and does not require any additional software. An NTFS-formatted external hard drive can then be used with any PC running a version of Windows that is later than Windows 3.
Plug the cable attached to the external hard drive into a USB port on the PC. Right-click on the "My Computer" icon on the desktop. Select "Manage" from the drop-down menu. Click on "Device Manager" in the left column of the window that appears. Click on the "+" icon next to "Disk drives" that is in the column to the right of "Device Manager." Right-click on the icon of the external hard drive. Select "Properties" from the pop-up window. Click the "Polices" tab at the top of the window that has replaced the pop-up window. Click the "Optimize for performance" button below "Policies." Click "OK" to close the window. Right-click on the icon of the external hard drive in the center column of the window that is still open. Select "Format" from the pop-up menu. Select "NTFS from the "File system" drop-down menu in the new window that appears. Click the "Start" button at the bottom of the window. Wait as a progress bar appears at the bottom of the window and fills in from left to right. Click the red "X" at the right corner of the window once the progress bar has completely filled in. format usb memory stick to ntfs http://www.online-tech-tips.com/computer-tips/format-usb-ntfs/
Overview and history of ntfs format http://www.pcguide.com/ref/hdd/file/ntfs/over-c.html
Apr 02, 2013 | Maxtor OneTouch III Mini Edition 120GB...
Whats the easiest way to recover info from a maxtor hard drive?
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Aug 16, 2012 | Maxtor Computers & Internet
My Acer Aspire e500 doesnot detect the HDD while installing both Win7 and XP but i can see the HDD if i connect to other PC
Try connecting to another PC as you mentioned and format the drive as NTFS.Do a full format, not a quick format, and the drive should be in prime condition to be read by the OS installers.
Mar 24, 2011 | Acer Aspire E500 PC Desktop
I have an external maxtor 3100 , FAT format on windows XP NTFS format. Is there a way to format my external unit NTFS? Appreciate your thoughts.
The FAT format is easier to recover data from if things go wrong, but if you insist on making it NTFS, all you have to do is right click the drive, choose FORMAT and then specify NTFS as the format.
WARNING!!! This WILL ERASE all the data on the drive so back it up first!
Feb 16, 2011 | Maxtor Personal Storage 3100 (M01E100) 100...
How can I connect and access NTFS formated hard drive?
Hello sir, hi try installing your hard drive to another pc with XP vista or 7 the ntfs drive will be read.
Oct 14, 2010 | Maxtor Shared Storage II (S01R320) Hard...
MY external hard disk maxtor is not detected
Is this a new Maxtor external drive? It came with a CD. Run the utility.
If there is no data on it that you want to save, you can also blow away the partition and format it:
Right-click [My Computer]
[Manage]
[Disk Management]
Find your external Maxtor Disk inthe list and / or graph
Right-click on the disk and select either "Format" or "Delete Partition"
(try format first) Use "NTFS quick format"
If you delete the partition, then "Create Partition" and then format.
You can assign a drive letter or accept whatever it assignes (probably Drive D)
*done*
Sep 30, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
I just installed a Maxtor 6L06033 (60GB) drive in my Essential 500. Why does it only format to 32GB?
1.the max configuration for this PC may only be for 40 GB
2. you may have to format the drive in to a 2nd virtual drive 32/22
3. check the manufacturers spec to see the maximum drive it can take.
Sep 28, 2009 | Gateway Essential 500 PC Desktop
Why cant i transfer any information from my macbook to the hard drive? It says it can only read the drive.
You might have formatted your HDD to NTFS. There are two types of format that can be done on Windows OS one is NTFS which can only be read/write on Windows OS and FAT32 which would allow you to work with both Mac and Windows OS. You may want to reformat your HDD on a Windows based PC as FAT32 before working with your Mac. If it is a USB HDD you may just simply go to My Computer then right click on the drive letter assigned to the HDD then select "format" option.
Jul 07, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
70 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
