Question about Maxtor Hard Drive
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
I have a Maxtor One-Touch 750gb external H/d and when the power adapter is inserted the power light comes on and goes out straight away an the H/d doesn't spin up or isn't recognized by the laptop.
I have tried the power adapter with another H/d and it works fine.
I was wondering if there was anything I could myself or if anyone has had the same problem as I lost the recipet.
I have the same problem with my Maxtor One Touch 4. The power light flashes on then goes out. However, the H/d does spin up, but the drive is not recognized by my laptop.
I have a 2nd Maxtor One Touch 4 external hard drive and it works fine. I utilized the same cables and still no connection for #1. Any ideas how to make this work? I have important data that must be recovered.
  • sestunna Jan 23, 2009
    same problem but my hd does spin then stops
3 Suggested Answers
SOURCE: Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
I have a new Maxtor One-Touch 750gb external drive. When I open "My Computer", it shows a RED line.. but I have 47 gigs of space free. Should I save my files and Reformat this external drive?
Posted on May 18, 2010
bronk50
  • 27725 Answers
SOURCE: I have a Maxtor OneTouch
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Posted on May 02, 2011
Transformer for Maxtor 1000GB has been lost. What are the specs for a replacement?
Maxtor One Touch 4 plus 1 terabyte external hard drive would need a 12 volt 2 amp power adapter with a positive inside tip.
That is if yours is the same model.
Oct 31, 2013 | Computers & Internet
How do I connect the hard drive for Maxtor One touch
Just use a standard USB cable to run from the drive to the computer's USB port, and connect the power adapter from the wall to the drive.
Feb 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
When I switch on the power on my external maxtor harddrive,it doesn' t show on my windows explorer.The blue light in front is constqntly flashing.What goes wrong? Thx lembi sr
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 31, 2010 | Maxtor OneTouch II external hard drive...
I have lost the power adapter of my Maxtor external hard disk (model One Touch 4). Please tell me where I can buy another power adapter or give me its technical specifications. I leave in the suburb of...
So take your Maxtor with you and hit the city , and for repair shop there . But before you go down there , you can search the web for repair shops in Paris . or try the Yellow Pages . ! Best regards Fathi Elmahdi .
Jan 12, 2010 | Computers & Internet
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor Onetouch 500GB went dead
if there is warranty take it back to the shop you bought it from.
Dec 31, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Maxtor Hard Drive Logo
29 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
