Question about Panasonic Cameras
There are (apparently) some strange "pictures" taking up enormous space on my panasonic DMC-FZ20GN. Oddly, they don't appear as images on the camera, but black screens. When I try to delete them, I get the message "some pictures cannot be deleted". I have tried a reset of the camera, but with no success. How can I get rid of them? Peter Townsend. Sydney.
  • peteytownsen Dec 28, 2008
    Thank you, Wiz - but I have a MacBookPro. I searched for "devices with removable storage section" but nothing showed up. Is there a way to do what you suggest (which sounds eminently sensible and logical) on a Mac? Peter Townsend.
  • peteytownsen Dec 29, 2008
    Thank you, FixYa Team. Problem solved. I got hold of a card reader and reformatted the card. Thank you, Peter Townsend.
  • 102 Answers
I think you have these locked on your camera. And usually when you see black it is a video.  Check out the info on the file when linked to your mac.  If it,s a video format you might need to view and delete in a video player program.
Posted on Dec 28, 2008
  • Kenneth Crowther
    Kenneth Crowther Dec 29, 2008
    why not rank one of the guys who gave you the solution?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially,there is a feature/provision on the camera to "format" the memory card while attached to said camera. This is an alternative to extracting the memory and formatting it using your Mac.
Good luck and Thank you for using FixYa.
    Genius:
  • 1,239 Answers
Hi
Plug your media card into a card reader on your computer and delete the photos there, or you can format the card from your camera and that will delete everything.camera manufacturer tech support recommeded this one
http://www.z-a-recovery.com/digital-imag...
I hope this also works for you.
  • ABHISHEK.C
    ABHISHEK.C Dec 28, 2008
    OR YOU COULD probably format the memory card in the camera. This will permanently erase all images that have been written to the card. To do this: Press ok - right arrow to Mode Menu - down arrow to Card tab - right arrow to Card Setup and then right arrow to Format - Choose Yes and then press Ok. All images are removed and going forward it should only download current images.
  • Panasonic Master
  • 13,433 Answers
Attempt to format the card in the camera, if you are unable to format the card you will need to buy a new card as the current one is most likely damaged or faulty.
copy your pictures into your mac first if there are important pictures and then format the card in the camera, there should be a option for that in the setup or settings depends on your camera, surely documented in the user manual.
  • 1,183 Answers
The only way to delete these pictured would be to reformat the card . If you have a computer that has a media card reader slot, insert the camera card into the computer. You would get an auto play pop select format the card.
If you donnot have the media card reader slot on your computer, connect the camera to the computer. Click on start and then my computer. Under devices with removable storage section, you would see your media card. Right click on it and then left click on format.
Caution: when you format the card , all pictures and things on the card would be lost
Thanks
proton
  • Mandeep  Singh
    Mandeep Singh Dec 28, 2008
    Follow the instructions below, to format the card
    connect the memory card to the Mac, launch Disk Utility from Applications > Utilities, choose the memory card from the left hand column, click on the Erase tab, choose MS-DOS File System from the Volume Format drop down menu and click on the Erase button
    Thanks
    Proton
    Note :If you are not able to delete the files , from the card , the same files maybe the system files for the camera , that it puts on the card. You can replace the memory card and check
Lumix camera DMC FZ20GN gives message please turn camera off then on again
It sounds like the camera just needs to be restarted. It might be an update that needs to be completely installed. Otherwise, some of the settings must just need to go back to default.
Elisa Jed ' http://aceboxes.com/index.php/electronics/camera-and-photo/camera-photo-accessories-1.html
Apr 12, 2014 | Panasonic Cameras
Lumix pictures blurry
I would suggest that the image stabilizer might not be working right. Could you upload a photo to Flickr or other location where I could look at the EXIF, or list it here. I would like to see what the camera is writing to the image as the settings when the photo was taken.
Does it make a difference when the image stabilizer is on or off?
Nov 23, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Horizontal lines on the images
If you have a bad CCD you will indeed need to replace it, but make sure you have thoroughly examined the user manual first as it may offer more insight into what's wrong with your camera. You can get it here:
Panasonic DMC FX30 manual
Mar 26, 2014 | Panasonic Lumix DMC-FX30 Digital Camera
I have a new Lumix DMC-FS11 How can I rotate video footage 90 degrees so it plays the right way when down loaded ?? Thanks
You can't. Not without special software and a *really* powerful computer. Rotating a video takes an enormous amount of number crunching and processing time and even then you'll suffer a very significant loss of quality.
Sorry this is not the answer you hoped for, but rotating a single still image is one matter and a video is a different ball game altogether.
Sep 30, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
Panasonic Lumix DMC-FX8 digital camera - marks on each photo
I was thinking along the lines of some kind of fungus if you were in a warm, humid climate.
May 03, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
DMC TZ3 Funny Pics
Like mem card problems. Try another in the camera, try reading card on a computer via a usb port card reader. Try reformating card using camera FORMAT function.
Mar 30, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
No image visible
I have a Delux Webcam "ZSMC USB PC Camera". I have a problem, the screen is black when I put the power on of the webcam. No pictures.
My E-mail: kdiecket@yahoo.fr
Dec 30, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-LC1 Digital Camera Problem
Contact Panasonic - there is a widespread problem with CCDs in the last 3 or 4 years - keep pressing them for free repair as is your due with faulty goods, even outside the warranty period.
See the following link:-
Widespread CCD problems in consumer imaging productsCCD Sensor Problems in Consumer Imaging Products .... Given that the Leica DIGILUX 2 is a variant of Panasonic's Lumix DMC-LC1 design, it isn't surprising ...
www.imaging-resource.com/badccds.html - 51k - Cached - Similar pages
Nov 11, 2007 | Panasonic Lumix DMC-LC1 Digital Camera
Panasonic fx01
I have somewhat of the same problem, I barely have used my camera as well and a new battery didn't fix it.  Oddly though, if I keep turning the camera on and off and taking the battery/memory card back in, pushing random buttons, eventually it turns back on again.  It's definitely not an ideal fix, but at least I can take pictures, albeit frustratingly.
Jun 25, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Where does Lumix® digital camera store the pictures I take?
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Aug 30, 2005 | Panasonic Lumix DMC-F1S / DMC-F1K Digital...
Cameras Logo
22 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
