Question about Microsoft Windows XP Professional
Folders take too long to open
I have the following Windows XP problem, which started appearing several months ago: When I click on a folder it takes a very long time to open. For example, today I actually encountered a situation when the time between the doubleclick on a folder icon and its opening was more than 2 minutes. I might add that when I type "explorer " on a command line, the folder opens instantaneously.
Regards,
bostjanv
  • bostjanv Dec 28, 2008
    In response to Eddie333and mangalarapu
    Thanks for your reply.
    "Does it happen on a specific folder or just any folder on your C:/ ?"
    I haven't noticed any particular slant in this behavior.
    "If its ANY folder then its a performance issue and you may have to do some defrag, desktop cleanup, temp file deletion. Also try disconnecting any network drives you may have as it searches this other drives."
    --I do defrags regularly
    --I don't have the habit of cleaning my desktop; but on the other
    hand I keep my desktop pretty Spartan and uncluttered.
    --temp files could be an issue because up to now my belief was that the system takes care of them. When I examined my %USERPROFILE%\Local Settings\Temp directory I found it had quite a few files. On the other hand, as I write later on, the situation has improved considerably but the previously mentioned temp file folder has not changed dramatically.
    --I don't have any network drives.
    However, there was an interesting development : when I wrote my original post, some folders took up to 2 minutes to open. At this moment they are pretty snappy, and they open at once. The only thing that could have influenced folder behavior in my view was a registry maintainance operation that I performed today. I cleaned up my registry with UniBlue Registry Booster. The operation found about 80 registry errors. However, I am not 100% sure that it was this action that improved my problem since I did not test folders immediately before and after the registry cleanup.
    --I have not tried disabling my antivirus software since at this moment the problem seems to have gone away
    In summary:
    I have this recurring and fluctuating (sometimes better sometimes worse) problem with folder opening time. Some of things Eddie333 and mangalarapu mention as helpful are
    -- defrag
    -- desktop cleanup
    -- temp file cleanup
    -- as large as possible RAM (my is 1GB)
    -- good antivirus and antispyware software (I use Norman antivirus
    and Lavasoft Ad-Aware)
    Perhaps the major question I have now is whether the registry cleanup operation I mention above (and you don't mention in your list) is likely to help when I run into this problem again?
    Regards,
    bostjanv
  • Ed Deguzman
    Ed Deguzman May 11, 2010
    Also if you have any anti-virus software try disabling it.
    Additionally if its opening in "Detail" view its loads much faster than if it were being open in "Thumbnail" mode
    Novelist:
  • 176 Answers
It might be too early to tell if by just cleaning the registry solved that issue you had earlier but cleaning the registry in general helps in better performance and fix error messages. Having no info about what its really fixing your best bet is to monitor it for a while and make notes when it does happen again.If it does happen again to run the registry cleaner and see if solves it again. It could also have been a missing or invalid references associated with the folder that the registry was able to clean up.
Posted on Dec 29, 2008
When I reported the problem some folders took up to 2 minutes to open. At this time they open normally. The only thing that could conceivable have influenced open folder time is a registry cleanup that I performed. However, I am not sure it was that did the trick.
Regards,
bostjanv
Posted on Dec 28, 2008
    Novelist:
  • 151 Answers
Solution:
let us try some troubleshooting steps, hope they will work.....................
i) Click on start button------>Select the option Control Panel ------>Select Printers and Other Hardware--->
  ----->Select Mouse----->Mouse Properties window appear-----> highlight or click Buttons Tab on the top
  -----> locate Double Click speed(in middle) and try move slide bar towards extreme right(towards Fast),
         now click apply and ok.....see the difference, if not try next one...........
ii) How much is ur RAM capacity(i would suggest > 1 GB RAM), if ur RAM something like 512 or 256     MB then you have to upgrade it to 1GB since you may face these problem with less RAM.....
   if you are running more no of application on a lower RAM it will take some time open any                  application or even something like opening a folder......
   if you have good of RAM, then try the next step...
iv) you can even apply single click option to make folders open faster
    Open My Computer ------> Select Tools option on top-----> Select Folder option ----> Select General Tab------> check single-click to open an item and then click apply and ok......
iii) sometimes it may be due to virus,spyware present in ur system so, i would suggest to install a good antrivirus, spyware software such as Bit Defender, Norton, AVG,......
When i click on new folder option it does nothing
Which operating system ?
Restore Folder Options in Windows XP
Windows XP has several viewing options that you can modify for folders in Windows Explorer. These include being able to customize whether you activate items by clicking them once or twice, whether Windows displays hidden and protected files and several other options.
If you have played with these options in an attempt to determine how you prefer to use your computer, you may accidentally reach the point where you have changed so many items that you are unsure of how to revert to the original configuration.
For this reason, Windows XP allows you to restore the folder options to their defaults by clicking a button.
Open Windows Explorer.
Two of the fastest ways to do this are by clicking the "Start" button and then clicking "My Computer" and by double clicking the "My Computer" icon on the desktop.
Click the "Tools" drop-down menu and select "Folder Options."
Click the "General" tab, and then click the "Restore Defaults" button if you would like to restore the default settings for the "Common Tasks" bar on the left side of folders, whether new folders open in the same window or a new window and whether items open with a single click or double click.
Click the "View" tab, and then click the "Restore Defaults" button if you would like to restore any advanced view settings to their defaults, such as whether Windows displays hidden and protected files.
Click the "Reset All Folders" button if you would like to restore the default viewing option to all folders, such as the detailed view or list view.
Click "OK" to save your changes.
http://support.microsoft.com/kb/812003
May 18, 2013 | Compaq CQ56-219WM Intel Celeron 900...
After cleaning the STOREJET 640GB by DoctorWeb, I can see only the separate files on it(which were out of folders).All folders are invisible on any PC.But when I connect it to TV I can see and open any...
Hello that means that your files properties are hidden in your PC. If your operating system is windows 7 you can change it by Clicking START, Control Panel and chose View by Category. Click appearance and personalization and click "show hidden files or folders", located under the "folder option" section. Choose the radio button that corresponds the "SHOW hidden Files, Folders and Drives" option. Uncheck the boxes that correspond to "Hidden protected operating system files". Then save the changes by clicking apply and OK.
If your operating system is Windows XP you change it by clicking My computer then double click the hard drive you want to open then click the view then chose show hidden files and folders.
Keep on touch best regards..
Aug 22, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
How to find a hidden doument that is taking up loads of memorey on a almio pro
If you are using Windows XP, to show hidden files:
1.
Open Folder Options in Control Panel.
Click Start, and then click Control Panel.
Click Appearance and Themes, and then click Folder Options.
2.
On the View tab, under Hidden files and folders, click Show hidden files and folders.
For Windows Vista and 7:
1. Open Folder Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clickingAppearance and Personalization, and then clicking Folder Options.
2. Click the View tab.
3. Under Advanced settings, click Show hidden files and folders, and then click OK.
May 08, 2011 | Computers & Internet
How do you import windows live mail from xp to windows 7 on another pc
Elaborate a little more .You can transfer mails from outlook to windows live xp .Follow the steps given below.
  1. The folder that contains the Outlook Express messages is marked as a hidden folder in Windows. To view this hidden folder, click Start, and then click Control Panel. Click Appearance and Themes, and then click Folder Options. Click the View tab, and under Hidden files and folders, click Show hidden files and folders.
  2. Locate the folder named Outlook Express. In Windows XP, this folder is located here by default: C:Documents and Settingsyour user nameLocal SettingsApplication DataIdentities{your Windows user identity number}MicrosoftOutlook Express.
  3. Copy the Outlook Express folder and all its contents to the Documents folder on the computer running Windows Vista.(You can store this copy of the Outlook Express folder in a locationother than the Documents folder, as long as you remember where to findit.)
Feb 01, 2010 | Computers & Internet
Weird folders appearing
those all are garbage folder, which are generated as a result of virus attack on your system, i strongly recomend you to format your main drive and reinstal the windows and this time also instal a powerful antivirus
Nov 05, 2009 | Microsoft Windows XP Professional
When i turn on my zune it just continues to restart. it showed a code 5 error message. What is it and can i fix it
you receive the message when A Windows Digital Rights Management component is corrupt.
Things to try
  1. Reset the DRM system on the computer. Warning This procedure affects all media files on the computer that use Windows Media DRM technology. The effect of this procedure is not limited to media files that you obtained from the Zune Marketplace. If you follow this procedure, content licenses for all protected media files on the hard disk are deleted. Other providers, such as, Napster, MSN Music, and Wal-Mart, use different mechanisms for restoring licenses. If you have content from other providers, examine the appropriate license restoration policies before you continue.To reset the DRM system on the computer, follow these steps:
    1. Verify that the Show hidden files and folders option is turned on. To do this, follow these steps:
      Windows 7 or Windows Vista
      1. Start Windows Explorer. To do this, click Start, type userinit.exe in the Start Search box, and then press ENTER.
      2. Click Organize, and then click Folder and Search Options.
      3. Click the View tab.
      4. Click Advanced Settings.
      5. Under Hidden files and folders, click Show hidden files and folders, click to clear the Hide Protected Operating System files (recommended) check box, and then click OK.
      Windows XP
      1. Start Windows Explorer. To do this, click Start, click Run, type userinit.exe, and then click OK.
      2. Click Tools, and then click Folder Options.
    2. Locate the DRM folder on the computer. Typically, the DRM folder is located in the following location. Note In these paths, drive represents the drive on which Windows is installed.Windows 7 or Windows Vista
      • Windows 7 or Windows Vista x86-based versions
        drive:\ProgramData\Microsoft\Windows\DRM
      • Windows 7 or Windows Vista x64-based versions
      Windows XP
      • drive:\Documents and Settings\All Users\DRM
      Note If you have upgraded from Windows 98 or from Window ME to Windows XP, the DRM folders may be located in C:\Windows\DRM.DRM folders can be located in various locations in different versions of Windows. You can also locate the DRM data path in the registry. DRM data is located in the following section of the registry:
      • x86-based versions of Windows XP, Windows Vista, or Windows 7: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      • x64-based versions of Windows 7 or Windows Vista: HKEY_LOCAL_MACHINE\Software\Microsoft\DRM
      To locate the DRM path in the registry, follow these steps:
      1. Start Registry Editor.
          Windows XP
          • Click Start, click Run, type Regedit, and then click OK.
          1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type run in the Start Search box, and then click Run under Programs.
          2. Type regedit.exe in the Open box, and then click OK.
            Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
      2. Look for the applicable folder based on the version of Windows that you are using.
    3. Rename the DRM folder to DRMbackup.
      1. Right-click the DRM folder, and then click Rename.
      2. Type DRMbackup, and then press ENTER.
      3. Close Windows Explorer.
        If you receive an “Access denied” error message when you try to rename your DRM folder, start the computer in safe mode and log in as the computer administrator. To do this, follow these steps:
        1. Restart the computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, press the F8 key when the Boot menu appears.
        2. Select the safe mode option when the Windows Advanced Options menu appears, and then press ENTER.
          The Boot menu appears again and the words "Safe Mode" appears in blue at the bottom of the screen.
    4. Reset the DRM security component. To do this, visit the following Microsoft Web site, and then follow the steps to upgrade the DRM security component: http://go.microsoft.com/FWLink?LinkID=34506 (http://go.microsoft.com/FWLink?LinkID=34506)
      Note When you access this site through Internet Explorer on a Windows Vista-based computer, you may receive a "user account control" popup message that requires that you enter the administrator password to continue. Note If you are running a 64-bit version of Windows 7 or Windows Vista x64 and the Upgrade button on the site listed earlier in this step appears dimmed, you will have to start Internet Explorer by using an account on the computer that has Administrative privileges in order to continue.
    5. Sign in to the Zune Marketplace. Then try to play a song to verify that the issue has been resolved.
    6. Restore the setting of the Hidden files and folders option. To do this, follow these steps:
Oct 31, 2009 | Audio Players & Recorders
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  2. On the Tools menu, click Folder options.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Madame, Sir, I subscribed for CorelWindvd9 after a month trial. I payd 29 ? for it, but I cann't open the programm. An additionnal key is asked after de seriesnumber is submitted. I deleted all of the...
Hello and welcome to FixYa . In order to re-install WinDVD 9, remove all traces of WinDVD manually only delete the folders if they exist, and if allowed.If you cannot delete a folder, try renaming the folder by adding .old to the name of the folder. You will need to show hidden files and folders on the computer on XP go to Start, All Programs, Windows Explorer,tools, Folder Options, View, Hidden files and folders, Show hidden files and folders. Using windows Vista Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, Control Panel, Appearance, Personalization, Folder Options, View, advanced settings, Show hidden files and folders, OK. The following folders will need to be erased.
Go to My Computer Use Start button, or on the Desktop. On Vista, Computer. Double click on C: drive, Documents and Settings and the folder named after your username.
When you reach the "InterVideo" folder, there will be a DVD9 folder, which is the one you are looking to erase. Note -This folder may be named Corel\DVD9 instead of InterVideo\DVD9 Erase the following folders Go to C:\Program Files\InterVideo or Corel delete the folder DVD9 Go to C:\Program Files\InterVideo\Common delete the folder Bin Go to C:\Program Files\InstallShield Installation Information delete the folder {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Go to C:\Program Files\Common Files delete the folder InterVideo Go to C:\Program Files\InterVideo\Common\ delete the folder Bin The second place to remove WinDVD 9 settings is in the registry.
Go to Start, Run type in regedit click ok. left hand column will be a list of items double click on HKEY_CURRENT_USER double click Software and InterVideo At the very end, when you reach the InterVideo folder,erase the DVD9 folder, by right clicking on it, and hitting Delete. Erase the following HKEY_CURRENT_USER\Software\InterVideo delete DVD9 HKEY_LOCAL_MACHINE\Software\InterVideo\ and DVD9 HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall and {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Restart the computer. Go to Start Run type in "%temp%" and hit Ok. Erase as many files as possible .In the "Edit" menu, click Select All, go to the File menu click delete.Say yes to delete Reinstall your software and it will accept your key. Hope this gets you going. Please Rate Me. And you can always Ask Me.aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 27, 2009 | Corel WinDVD 9 Full Version for PC
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
Could not select "show hidden files & folders" in folders option
go to system registry.......click start then run and type regedit then find this key HKEY_ LOCAL_MACHINE software microsoft windows current version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....and create new DWORD key and give the name CheckedValue and enter 1 into value data.......
restart your pc..........
good luck.........
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Jul 30, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
1,855 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
