Question about The Singing Machine Singing Machine SME399 Dual Cassette Karaoke System w/AM/FM Radio Boombox
STVD-1001 pedestal singing machine has bad power supply
The power transformer in the bottom unit of my STVD-1001 has failed and has tar leaking out of it and no voltages at all. I don't know if the logic board is bad but could be. The numbers on the transformer look like 1G 203S10010240 AND T76-0611067-10. I think thats right but could be off by a little bit due to hard to see into the unit.
The logic board shows 48-32D605100121 with the same disclaimer as above for the transformer.
The lower unit contains just these parts and houses the sub-woofer. The upper unit, where the player is located, is fine. Hope you can help.
John
4 Suggested Answers
maineguide
  • 19 Answers
SOURCE: cd & g drive quite working
I had the same problem. The fix is a bit unorthadox. I removed the 4 screws holding the circuit board that is mounted directly under the CD player. Now with the board hanging free the unit works fine.
Good luck.
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: I have the singing machine stvd-919 need remote.
We have this same Kareoke machine but need to fond the remote. Please advise
Posted on Sep 26, 2011
caroldon
  • 17130 Answers
SOURCE: I have a STVD-919 that at times freezes up than starts again, freezes up putting words on top of each other. Will never buy another Singing Machine second one with problems and company has no place t
These are rare model with a limited service support and it is important that you need to get this part ONLY if the failed unit has a universal replacement which must be checked physically with any electronic showroom. If this is not properly confirmed please do not spend any more money on it as a replacement also can be short lived if the quality of spare is poor.
Posted on Dec 06, 2011
Samsung printer 110v plug to 220v
You would have damaged the power supply section but in many cases the front end contains a surge protector with a variator which will short and blow the fuse. So check fuse replace and check for short in the input circuit of the power supply, if the Switch mode is damaged then you need to replace the unit with a 220 volt type or if only the 110 type is available then use a step down transformer to down the mains to 110V with about 0.5Amps
Oct 03, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
I have a STVD-919 that at times freezes up than starts again, freezes up putting words on top of each other. Will never buy another Singing Machine second one with problems and company has no place to...
Dec 06, 2011 | The Singing Machine Audio Players &...
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Is there a universal remote code for stvd 919 singing machine. I have lost the original remote
Please advise if a universal remote would work with this model kareoke
Nov 22, 2010 | Televison & Video
Nov 24, 2009 | The Singing Machine DVD/CDG Karaoke System...
Cd & g drive quite working
Good luck.
May 19, 2009 | The Singing Machine DVD/CDG Karaoke System...
I want to get the video feed of my family singing to show on my TV and not on the screen of the karaoke machine. I have a Singing Machine STVD-919
Ok from the looks of it... the three RCA plugs on the bottom left are the video out audio (right&left) out use the video out and plug that into your video in on your tv then for sound do the same for the right&left audio
Dec 24, 2008 | Audio Players & Recorders
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
125 people viewed this question
Top The Singing Machine Audio Players & Recorders Experts
 Grubhead
Grubhead
paul
Are you a The Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
