Question about Lionel Toys
Non-functioning horn on lionel 621 switcher
The engine is mint in box but has been in the attic for 46 years.
This is the first time I ever removed the cover since 1956 when I bought it. I just lubricated it and it runs great but the horn only hums/buzzes when when I hit the button on the transformer. I am running it on fast track. I don't know if that makes a difference in horn performance.
I would appreciate any in you have to solve this issue.
Thanks,
John
  • John Verruso Dec 28, 2008
    Dear Fix ya,
    Yes, the issue still exists but I'm not interested in any plan to fix it because I will figure it out. It's just a matter of time and finding the wiring and parts service manual. I was just interested in finding out if someone else could share a similar issue and resolution with me without making a buck.
    Thank you.
    fenderstrat7
    Top Expert:
  • Lionel Master
  • 12,962 Answers
The horn has a screw in it to adjust the pitch. Try adjusting it to see if you get sound.
Posted on Jun 25, 2017
4 Suggested Answers
RyanFanMan
  • 342 Answers
SOURCE: 3 year old Lionel 4-4-2
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Posted on Jan 02, 2011
  • 13 Answers
SOURCE: I have a Lionel ZW transformer older version
bad track connection.... clean the track with dry scotchbite pad, then wipe with soft cloth, or the connection pins are loose in the track. tighten with needle nose pliers
Posted on Nov 20, 2011
technowee362
Just wanted to add a note to this problem you are having....Question is this...How big is the train layout and how many power clips do you have on the track??
Reason is being if you only have one power clip for the whole track, you will notice a decrease (slowdown) of the train in certain area(s) so i would recommend adding another power clip or two to your layout, also If you are using old regular O track, make sure you have the metal pins in all 3 railsHope this helps
Posted on Apr 06, 2012
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
How to hook up lionel #41 to gateman and power supply
Here is the manual for the switcher. http://www.lionel.com/media/servicedocuments/71-8474-250.pdf
Here is a link for gatemen, select the one you have to find the manual.
http://www.lionel.com/Products/Finder/SearchResults.cfm?doAction=search&Keywords=gateman&CategoryID=39&Gauge=&RailLineID=&CatalogID=&CollectionID=&searchWithin=Current
Here is the link for power supplies.
http://www.lionel.com/Products/Finder/SearchResults.cfm?doAction=Browse&CategoryID=40.
Apr 16, 2014 | Crafts & Hobbies
Horn diagram
NEED DIAGRAMM OR LOCATION?THE HORNS ARE LOCATEDBEHIND THE FOG LIGHTS AT THE RIGHT AND THE LEFT ONE.THE FUSE IS A 20 AMPS LOCATED AT THE ENGINE COMPARTMENT FUSE BOX NUMB 46.IF U NEED MORE INFO LET ME KNOW
Mar 07, 2014 | Volkswagen Jetta Cars & Trucks
How to uninstall non responding applications on pc
1 go to start and wright in the searchbox msconfig than enter
2 in the box you find the section with start
there you find the ip switcher and unsigne it from the start list.
3 get the iobit uninstaller and remove the ip switcher.
Sep 18, 2013 | Chris Knox IP Switcher Widget
Were to put smoke fluid on a lionel 8141
If you are asking about the 2-4-2 scout type, a few drops down the stack.
If you are asking about the diesel switcher, it has no smoke unit.
Feb 24, 2013 | Lionel 8141-50 Smoke Unit
My c200 year 2000 got problem with horn, i just went to service my car after that i switch on my car the horn swtich on automatically and non stop ,after awhile, my mechanic fix again and now no more
Often we find that the horn pad becomes loose and requires adjustment, you need to take it to a mechanic to be adjusted, they need to remove the air bag and adjust the spring loaded screws, that should fix your horn, I doubt it has anything to do with your air conditioning repair
Dec 31, 2012 | 2002 Mercedes-Benz C200
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
Sep 01, 2011 | Rio Grande Lionel 34500 Ft Diesel...
My cw-80 Lionel transformer has button issues when operating both traditional and tmcc loco. the horn and bell sounds are goofy. and on some of my traditionaltenders the sounds are still on when the...
The CW-80 is not suited for electronic sound systems. The output is non-sinusoidal. When electronic sounds are generated for some locos, the sound will be garbled. Use another power source. The Z1000 MTH power source or similar is recommended as are many other older Lionel standard power xfmrs. For the sound stay on problem with switch off, try putting a fixed load on the tracks ie: An accessory of some kind (lights etc). Usually a fixed electrical load will fix this problem. Overall, I would recommend changing out the power source and save yourself a lot of headache..
May 14, 2011 | Lionel Cw 80 Transformer
Why is a ''D'' battery needed for my Lionel Diesel engine?
This is just a guess but it may have powered headlights or other lights on the train at one time, some of then even had a smoke producing device on them.
Mar 19, 2009 | Lionel New Haven Freight Train Set
Fuse diagram
The fuse box is located under the engine hood on the left side, near the upper strut housing or near the battery. it should say which one controls the horn either in the back of the owners manual or under the fuse box lid. if not the fuse than the horn itself might be bad. hope this helps
Jan 02, 2009 | 1999 BMW 318 ti
Toys Logo
80 people viewed this question
Top Lionel Toys Experts
Marvin
Marvin
Paul Bade
Are you a Lionel Toy Expert? Answer questions, earn points and help others
