My display is not working hence need step by step guidance to copy contacts from phone to simcard
SOURCE: phone to sim contacts on Samsung SGH-D807
The D807 doesn't have the option to copy all contacts to the SIM from the phone by using key presses on the phone, only to the phone from the SIM. Best solution, if you still have the CD and USB cable that came with the phone, is to use the software option. The management software allows you to manually move all those contacts to the SIM, or to your computer, which is a better idea because the SIM doesn't store the data in the same way so some is lost. For example, the phone stores a name as two separate parts, first and last, but the SIM only has a single data entry for the name so you lose the last name from each of your contacts if you directly pass the data to the SIM.
SOURCE: copy contacts
If you try downloading PC Suite from Samsung, this should help sort out your problem as it has a contact back feature within it.
http://uk.samsungmobile.com/supports/softwaremanuals/pcStudio31.do
SOURCE: how to transfer contacts frm samsung guru100 broken screen to sim
Try samsung PC Studio software free on their website.
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SGH-A707&mType=SW&vType=L&disp_nm=Sync(SGH-a707)
It works with my sgh-a707 and might work for yours. They might have different software for yours so check that site out. all work is done by computer.
SOURCE: COPY PHONE CONTACTS TO SIM ON THE SAMSUNG G600
Press the following buttons:
Menu (left 'hot key'), 2, 7, 2, 2
That'll do it! :)
-ComradeHaz
SOURCE: My Samsung SGH-t659 displays "Phone Freeze SIM
I have experienced this issue and I would take the phone to a service provider location As Soon As Possible to have the issue corrected.
