Question about Metrologic Instruments Voyager BT MS9535 Handheld
Whats the reset codes for my barcode reader on a esp smog machine
I have a bar code reader that's not reading the codes properly or better yet at all. I know there is a sequence to program my bar code rteader for my smog machine in California could somebody help please.
bluegreenash
  • 661 Answers
SOURCE: My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Posted on Oct 04, 2007
SOURCE: Default Barcode as the one used in the manual
I finally figured out the problem, thanks to Here4you's help.  The Metrologic VoyagerBT does indeed use the 128 barcoding protocols.  The reason my barcodes were not scanning in properly is that the correct barcodes had a hidden "Function-3" prefix, which all of the scanner's programming codes have.  I am still having trouble figuring out how to input a "Function-3" prefix into the various barcode generation programs I am testing.  I use Macs, not PCs so many of you may be inclined to recommend certain programs that are are exclusively made for PCs.  I will be creating the data for the barcodes in either Excel or Filemaker, so I am attempting to input the ASCII equivalent for the Function-3, with mixed results.  Thanks for the help!
Posted on Jan 09, 2008
SOURCE: metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Posted on Jan 21, 2008
  • 18 Answers
SOURCE: Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Posted on Apr 02, 2009
Yogger
  • 117 Answers
SOURCE: Hello, I have the Motorola LS3478-FZ
Hello Mathew,
the USPS barcode is the GS1 128 (Code128) that will help you by activating accoring to the manual. Please be sure that you enable all lenghts of the Code128 barcode. That is probably the issue.
Posted on Sep 21, 2010
How to get 2003 pt cruiser turbo to pass smog and referee. Had it to 4 great shops and called other Chrysler dealers. Followed the driving test to reset the computer. Over 1000 miles to no avail.
resetting a computer program is done with a scanner or fault code reader
any thing else is a waste of time
has any shop bothered to read the fault codes properly
Jul 22, 2015 | Chrysler Cars & Trucks
Tip
How do I read barcodes from an Adobe PDF FILE?
<p>Reading a bar code in a portable document format (PDF) document is a simple procedure. Some newer phones come with smart barcode scanners, and you can scan the Internet to buy. A barcode is a series of lines of code that identifies a product. When you print the document with a single piece of technology, you can read a barcode in a PDF document. <br /> <p><br /> <p>1. Open the PDF document. Adobe Reader PDF reader is the most common. If you do not have Adobe, download the latest version of the company's website for free download (see Resources). <br /> <p><br /> <p>2. Select "File" drop-down box to the left of Adobe. Select "Print" and then "OK". <br /> <p><br /> <p>3. Set the bar code scanner. Jumping the gun and a horizontal red line is designed with the focus of the scanner. Move the line through the barcode printed on the document until the scanner beeps. Release the trigger and see the screen on the back of the scanner, which will give you the information encoded in bar code. <br /> <p><br /> <p>4. Download a barcode scanning application for your smart phone if you do not want a handheld scanner. Most bar code applications are free. Open the program and point the camera at the barcode in the PDF. Wait until the camera for a snapshot of the barcode will not make up the barcode in the light of the entire camera to take. The program will decode the barcode and display the results. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
Hello, I have the Motorola LS3478-FZ barcode reader and am having a strange problem. This is a wireless reader, and the cradle is plugged in via USB. The reader seems to scan any barcode I give it,...
Hello Mathew,
Aug 19, 2010 | Zebra LS3478-FZ Handheld Rugged Cordless...
I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at support.symbol.com. Here is a short cut:
http://tiny.cc/d400s
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
Mar 05, 2010 | Zebra LS4278 Cordless Bar Code Reader...
Bar code reader cannot be recognized by the computer
i think it is a softwere problem .once a time you reinstal same bar code reader driver, thanks
Jun 16, 2009 | PSC Duet RS-232 Handheld Barcode Scanner
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
Mar 05, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Jul 04, 2007 | HHP IT3800 Handheld
The problem with reading the barcode
Be sure the Flic scanner is set to the factory default configuration by scanning the Defaults bar code given above. Then check the Format options for Characters to Strip and Characters to Append (see page 10) and make sure these are set correctly. In order to scan the ?Factory Defaults? bar code in the Flic Operator?s Guide to reset your Flic scanner to the default settings: Select Flicware , Tools , Format and add the appropriate control character(s) in the Characters to Append box. Good luck.
Dec 05, 2005 | MicroVision Development HS2121-MV
Metrologic Instruments Voyager BT MS9535 Handheld Logo
822 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
