Question about Sony FWD-50PX2 50 in. Plasma Television
Sony Plasma TV.
I plug in my plasma tv and the standby light turns green and it makes a clicking sound but it never turns on. After about 10 seconds the clicking sound stops and the green light turns red. I press the power button and nothing happens. My TV just went over warranty which makes this problem that much crappier. How convenient. Please help me.
  • 2 more comments
  • mike1parker Feb 07, 2009
    My Sony plasma 50PX2 is doing the same thing. It began after I heard a loud pop and turned off. The pop turned out to be a blown 4A 250V fuse on the Y sustain (Y-SUS) board. I replaced the fuse, but it blew again right after plugging in power. The Sony repair manual, which is almost useless, indicates a possible problem with the A board. The A board is where all the video connections are. I'm more inclined to think the problem is the power supply board (G board). Another post on this site from a user with a similar problem said his Y-SUS board was the problem. I'm going to try checking voltages and see if I can confirm.
  • Mark Mark Feb 21, 2009
    whe i plug in my plasma tv and the standby light turns green and it makes a double clicking sound 5 times it never turns on. After that the clicking sound stops and the green light turns red. I press the power button and nothing happens.
    When I plug in my plasma tv and the standby light turns green it makes a double click sound 5 times but it never turns on. the green light turns red. I press the power button and nothing happens.
  • Anonymous Mar 22, 2014
    Plasma, clicking sound
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Posted on Oct 31, 2009
  • PimS Jun 04, 2012
    Hello Gaston, did you ever find out what part gave the problem?
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
I have a hitachi 55pma550 plasma tv.when I turn on the main switch red light comes on standby. But when I turn on tv the red red light on stand by turns green only for 10 seconds and goes red no picture...
It's most likely the smps. You'll first need to check voltages at CN63, pin #1-(+5v), 3-(+3.3v) and pin 8-(+6v) Also check CNPPS, pin 1-(+30v), 4-(+5v), 8-(+12v), 12-(+10v) absent these values and the power supply is clearly the problem.
Jun 30, 2011 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony plasma standby light flashes 8 X, won't stay on
when pluggin power it turns on and immediately move to standby
Dec 28, 2008 | Sony PFM-42X1 Plasma TV
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Sony FWD-50PX2 50 in. Plasma Television Logo
498 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
