Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Funny sound during water spraying
Once the water fills up and the water starts to spray it sounds funny almost like there is water in teh line. I opened it numerous times to make sure it wasn't something floating in the bottom or dishes hitting. It's defiinitely in the mechanics. Just as I am typing it is adding a new sound. Sounds like a paper shredder. Vibrating the whole floor. This is supposed to be the quiet model! It's only a year old! UGHH
  • Anonymous Jan 31, 2009
    After being in service about 12 months....my JDB1100AWS started making very loud clicking-grinding noises when pump was running...service tech came out and diagnosed it as bad motor....replaced the entire pump/motor housing...fixed it.
    now..5 months later...similar problem is back. I think there is a design problem with the motor...My whirlpool dishwasher at my rental has simlar sounds....was silent when i bought it...now noisy
  • Kris Seymour May 11, 2010
    Hi what make is your d/washer?
    Scholar:
  • 86 Answers
Hi i am not to familiar wit this product but to me it sounds like the wash pump maybe faulty? Have a look underneath if you can and see if there is any water or parts laying on the floor. We might then be able to solve the problem...
Posted on Dec 30, 2008
Hi my sh ge90 equaliser has started to make a funny noise.it works but it's making the sound really bad can anyone help?
It could be dirty contacts , try buying a spray switch cleaner , and moving the switches.
Oct 15, 2014 | Audio Players & Recorders
I am experianceing fuel problems at the trottel body carburator the injectors are makeing a funny buzzing noise when throttle is pushed but I get no fuel
Does the fuel pump work?
Do you have fuel pressure?
I assume it will not start
Does it start when you put gas in a
spray bottle & spray the throttle body
Jun 28, 2011 | 1992 Chevrolet K1500
I push bulb and air flows toward tank. I have replaced both lines. taken carb off and cleaned and reassembled. still same prob hence it will not start.
There are check valves in the primer base assembly of your carb. They allow gas/air to flow in one direction but not the other. They can go bad and cause assorted problems, fuel movement to and from the carb being one. Remove the cover with the bulb and the fuel line to it. Liberally spray with WD-40 on the carb and into the fuel line itself. Put the bulb back on and "work it" a little to get the lubricant flowing to the right places. The WD-40 will also help clean this part of the carb. regular carb spray cleaners are way too strong and can damage the sensitive parts in these carbs. Don't use any and dont ever soak it in carb cleaner. Only spray clean it with non-flammable brake cleaner. Sounds funny but it works and won't hurt the delicate carb parts. Good luck because you may need to rebuild the thing even after it is cleaned.
Sep 02, 2010 | Craftsman 25cc Gas Line Trimmer
I am receiving a message, "paper jam", yet there is none. At the same time, It goes to sleep. How do I get it to awaken? Any assistance is appreciated.
LOL, I know it isn't funny but it sounded funny. There is probably a small particle of paper stuck inside it, and that little peice of paper is telling the machine to sleep until the paper is removed. Try spraying some keyboard cleaner where the paper goes in and where the paper goes out.
Aug 06, 2010 | Brother IntelliFax-2820 Laser Fax
Dish washer, Water leaks out of right front corner during first
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
Oct 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Overheating, idling funny
try getting a higher number in thermostat like a 180. replace the cap it may be malfunctioning anf finally the overspray will cause things to go wierd spray down with water and things should improve.
May 18, 2009 | 1994 Honda Accord
Timing belt single cam eng.
have you disabled the computer control for the timing advance when you set the ignition timing. if so check for loose vacumn lines
Jan 31, 2009 | 1997 Dodge Neon
Icemaker not working.
I just had the same problem. I found a small amount of ice formed under the water inlet point in the ice maker tray. This ice prevented the rotation of the "ice cube ejection fingers" so it couldn't cycle and re-fill. I used a hair dryer to melt this ice and the fingers immediately began rotating. Once they cycled, the tray filled with water as it should. All seems well now.
Jan 18, 2009 | KitchenAid KSRS25IL Side by Side...
Dishes don't get clean. soap still on inside of door. . . water coming up to fill line and hot enough and dishwasher drains after cycle, spray arms are clear. . . help!
Water from the wash arms must be able to reach the detergent cup during the wash. It sounds as though the machine may be over-loaded during the wash and water does not cause the detergent to mix with the wash tank water. Try washing a cycle with nothing in the machine. Does the detergent still stick to the door?
If no, the machine is overloaded. Wash fewer items or smaller items so spray will contact detergent.
If yes, you have probably lost wash pressure. Clean all screens and jets.
Hope this helps,
Kermit
Aug 13, 2008 | Dishwashers
Re: Maytag dishwasher
does the timer advance the control knob? check to see that nothing is in the way of the center spray tower. does it sound like any water is spraying around inside?
Sep 01, 2007 | Dishwashers
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
222 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
